Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-26-2011, 09:35 AM
egrofal egrofal is offline
Skid Plate?
97 Bonneville.
My plastic skid plate under the front end and front half of the engine became undone and is scraping on the ground. This happened at 40 MPH and sounded like I blew a radiator hose, but the car was cold and there was no smoke. The bolts rusted away. Is it okay just to amputate the skid plate the rest of the way? What's the purpose? I am guessing at the name "skid plate". What purpose does it serve other than scraping on parking blocks?
Anyone there?
Old 12-26-2011, 10:03 AM
Tech II Tech II is offline
Re: Skid Plate?
Are you talking about the air dam?
That is there to force air up and through the condenser/radiator.....helps to remove the heat from the radiator/condenser...
Old 12-26-2011, 12:47 PM
Re: Skid Plate?
Okay, it's an air dam alright.
I took it off. I hope the car doesn't overheat. I keep an eye on the temperature.
Old 12-26-2011, 08:39 PM
maxwedge maxwedge is offline
A990 racer
Re: Skid Plate?
No issue in Ill. this time of year, but next summer maybe.
Old 12-26-2011, 11:33 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Skid Plate?
You are very unlikely to overheat the car, so long as the radiator fans are operational. You might find the fans kick-on a bit more often during summertime stop-and-go driving. Otherwise you should not have a problem.
Old 12-27-2011, 11:35 AM
Re: Skid Plate?
I took it off the rest of the way. Metric hex screws. Also I found that part of the air dam was melted by the belt wheel. so that's were I was getting a burning plastic smell the past 3 years! My bonne still has life and good tires and gets me back and forth to The J-O-B. I found some old oil in my garage. was still clean, said 10W40 on it but was pretty thick when I poured it down at 50 degrees. Is it possible it dried up like an oil painting? It was at leat 8 years old. It was like a thick honey. About a half quart in plastic can so it had to be no older that 1980. I hope my filter don't choke on it.
Old 12-27-2011, 05:59 PM
Re: Skid Plate?
Only vehicle I ever saw have an overheating problem, because the lower air dam was removed, was a Firebird.....
In the winter, because the firebird was so low, it became a plow with no traction....
AC skid plate rrdstarr Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 11-22-2001 12:33 PM
Skid Row Front Skid Plate Mod rhombus Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 18 11-10-2001 07:24 PM
Calmini fuel tank skid plate Toy Man Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 20 10-11-2001 10:58 AM
Pics of KMA front bumper and skid plate rednec Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 22 09-10-2001 11:41 PM
Droppping Diff and Skid Plates Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 07-23-2001 11:47 PM
