Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 09-22-2002, 08:27 PM   #1
dwayne1224
econoline headlights
I have a 1997 ford E 150. The headlights have quit working. The bulbs are good the fuses are good and the relay is good. I NEED HELP. I use this van for my job without headlights i cant work.
dwayne1224 is offline   Reply With Quote
Old 09-26-2002, 07:10 PM   #2
fordman123
Good possibility is that the headlamp switch has gone sour!!
You might want to try that or get a wiring diagram and check your voltages and grounds first.
If you need more help, reply to this post and I will try to help you further.
Good luck!
Fordman123
Technical Consultant
fordman123 is offline   Reply With Quote
Old 03-18-2009, 07:04 AM   #3
bearsfan1967
Re: econoline headlights
I have the same problem. how do you replace the headlight switch?
bearsfan1967 is offline   Reply With Quote
Old 01-07-2012, 11:38 PM   #4
teambldr
Check the dimmer switch first. I had the same problem and it comes back to the dimmer/wiper control/turn signal unit.
teambldr is offline   Reply With Quote
headlights davidrobert2 Intrepid 1 11-20-2009 03:02 PM
Back up camera for Econoline and Ford vans csorb Econoline 0 05-18-2009 01:04 PM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 07:40 PM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 07:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
