Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-17-2001, 08:01 PM
Chekmi21 Chekmi21 is offline
Send a message via AIM to Chekmi21
Turbo charger or super charger?!?!?!
First off...what is the difference between the two.
Second...how much will it increase my horsepower.
Third...how much does it cost installed?
Old 10-17-2001, 08:27 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Turbo charger or super charger?!?!?!
Well, first of all, some folks also call a turbocharger a supercharger. Both make power by taking in ambient air and compressing it into the engine, basically stuffing more air into the engine than it can suck in by itself.
Typically, a supercharger is driven off the crankshaft while a turbocharger is driven by exhaust gases. A properly sized turbo will kick supercharger ass any day. There is a common misconception that superchargers have no lag while turbos do. In fact, superchargers lag as well and a properly sized turbo will spool up significantly faster than a supercharger.
Turbos kick supercharger ass.
How much money do you have?
That depends upon how much power you want to make, which is, of course, dependent upon how much money you have.
I'm being funny, but there is no set answer to question number 3 and question number 2 has no specific answer. An SR20DET can be made to easily (and relatively cheaply) make 250 bhp. You can get a turbo SR20 to make 500 hp to the wheels if you have enough money (and more if you have more money).
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-17-2001, 08:46 PM
OK so the rumor I heard about superchargers working at low speeds and the turbocharger working at high speeds is false?
Also where would I go to get a turbo charger?
So if I wanted total power of like 250 or so hsp....then how much would that cost me?
Old 10-17-2001, 09:09 PM
P10DET's Avatar
Yes. It's a common misconception. There are lots of reasons for it and I used to even believe it. The fact is, a [i]correctly[/u] sized turbo will build boost faster than a supercharger and will work better over a much wider rpm range.
I would do a search on the web. If you want to buy a turbo, get a Garrett. You will actually want to either buy a kit or a SR20DET. Kits are available from Hotshot and F-Max.
Figure about $2,000-4,000.
George Roffe
Houston, Texas USA
00 328i
Old 10-18-2001, 10:41 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Click here for a more in depth description. Pull up a seat, it's a lot of reading.
Click here
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 10-18-2001, 11:51 AM
P10DET's Avatar
Click here
Just be careful. The guru has made some statements that are not true. One major one is that turbos lag and superchargers don't. I still say if you want a excellent primer on forced induction, read what Mike Kojima wrote in SCC in his Suck, Squish, Bang, Blow series. Mike is an engineer working in both the OEM field and performance aftermarket. He used to work for TRD building racing engines.
For another resource on the discussion, check the SE-R Mailing List archives. They include some excellent technical information about turbos vs superchargers with a lot posted by Rob Cadle, an engineer for Garrett Turbos. Don't think that Rob is biased. He works with superchargers too (for big rigs). Rob and Mike both go into depth about the advantages of a turbo over a supercharger and the popular myths about both.
There are a lot of myths and misconceptions when discussing turbos vs superchargers. A lot of the myths about turbos is based upon old school turbos and turbo systems. I know because I used to believe the myths and know better now.
Lastly I'll say this for now.....
I think you will find turbos to work better in situations with a wider rev range than a supercharger will. That is because a turbo is not dependent upon engine rpm for shaft rpm. So, a properly sized turbo will make boost sooner than a supercharger. Also, in racing where superchargers andturbochargers are allowed, you will find turbochargers. In Top Fuel drag racing you find superchargers because turbos are banned.
George Roffe
Houston, Texas USA
00 328i
turbo & super charger moha_modi Forced Induction 6 09-07-2005 04:25 PM
IS300 Turbo or Super Charger? GTO4Life Forced Induction 21 07-29-2004 04:17 PM
2000 GT-S and turbo charger/super charger 00 Blk Celica GT-S Celica 6 03-28-2004 04:18 PM
Turbo Charger or Super Charger?? HiPo_DRIVER Integra 4 04-13-2002 08:21 PM
turbo charger vs. super charger bluevette74 Car Comparisons 12 12-05-2001 08:52 PM
