Old 02-20-2004, 12:59 AM
TopDogg TopDogg is offline
89 TBI problems. Running bad
89 4x4 350 with TBI First it started as small problem. Take off from a dead stop like a normal driver would and you do OK. If you are at any cruisen speed and try to accelerate over half throttle motor would start to cough a bit and not want to accelerate under hard load. Running this way for awhile. So up at about 3k RPM it wont let you accelerate smothly but you can ease your way to 60mph or so.
By the way this is a truck I am close to buying. He drives by my house daily and it sounds good going by.
He came home tonight and shut truck off. When restarting hot it hesitates and he actually had to hit the pedal to start it. Almost seems to be running rich. I took off the air cleaner to see how injectors were spraying. When we gave some gas it backfired (big flame) through throttle body high enough to hit the hood. He said it has been running real "doggie" a pooch I guess. My guess is a problem is progressing and I want to know what it is before I buy. I had a Camaro 1991 with a 305 TBI that started doing the exact same thing with the cutting out like it was losing spark under any hard load. Cant really say for sure I never had this problem.
He just replaced the cap rotor and wires. And no improvement.
It also has an exhaust leak at the manifold/head under first port that you can hear but cant see. Arent the factory manifolds gasket free? I couldnt imagine it beeing anything else.
Any opinions
Old 02-20-2004, 01:15 AM
Some more important details
When truck is in nuetral (park) it will rev up fine. Vroom vrooooom Vroooooom
Only when driving will it (except for that one time) start kicking spitting or what ever the hell it does. Its not my truck yet so I cant start trouble shooting. Was suppose to buy it tonight but he need a way to work tomorrow.
Old 02-20-2004, 10:55 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: 89 TBI problems. Running bad
Sounds like a spark problem. I know all of it has replaced, but what if there is a bad plug, or a grounded wire. Also... how is the timing?
Old 02-21-2004, 01:05 AM
rkt-mn rkt-mn is offline
Talking dude !! fule filter !!!!
change the fule filter!!!!! I had the same problem w/ my 94 SUV I did every thing from plugs wires time and my mechanic told me to change the Fule Filter !!!
Old 02-21-2004, 01:06 AM
Bought the truck tonight. 89 4x4 350 TBI. NO RUST (reason I bought it) $1400
It cuts out under load. Sometimes when I am accelerating at about 40 and I let off a little on the gas it will actually PICK UP speed.
If I accelerate hard and let off it will back fire but not all the time.
I get to trouble shoot now. Yippeeee Owell atleast its a Chevy.
But I am still looking for opinions.
Old 02-21-2004, 01:53 AM
I think he said he did change the fuel filter. But I plan on checking the EGR valve, coil and pick up coil and I will probably add a new fuel filter when I am at it. A fuel filter is one thing I do right away when buying a used car.
Old 02-21-2004, 10:18 PM
DISTIBUTOR hold down clamp was loose. Checked the timing the morning after I bought it and it was way off. A little adjustment and it runs great. And paid for.
Old 02-21-2004, 11:38 PM
desertmike1 desertmike1 is offline
You did good, TopDog!!
Old 02-22-2004, 03:32 PM
NWChevyGuy's Avatar
Thats sweet! Thought that might have been it. Had the same problem in a truck of mine once. Right on
Old 02-24-2004, 11:44 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
Good to hear man glad to hear there are some other people that got a good deal on an old workhorse. I got my 89 C1500 for $250.oo and had to put a new driveshaft in ($125.00) P.S. if you ever need a used driveshaft dont bother looking on the East Coast I checked every junk yard I think I got the last one .
Old 02-24-2004, 11:46 AM
P.S. 218,000 on orig. motor, tranny. My motto "if it dont leak and burn oil it aint a chevy"
Old 05-27-2006, 12:00 AM
halofton15 halofton15 is offline
I recently bought a 93 ck 2500 with 478,000 miles on it, was excuvation company truck original motor believe it or not clean truck, truck misses and is sluggish and sometimes stalls at takeoff. I replaced cap/roter plugs/wires and made sure firing order was correct, new fuel fiilter ran a code test and 32 came up so I unpluged vac.hose from the egr and it died,I have made sure silanoidconected propably, it is. I replaced all vac. hoses and tested. I even checked fuses. I don't know how to tell if the egr silanoid is bad and I don't know where the t/b wire is. I have a few more things to try but still looking for suggestions.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 12:05 PM
Look,this is weird. Bad plugs=runs good, Good plugs=runs bad browserealty Villager 6 08-28-2007 10:05 PM
PROBLEM 3.1 car RUNNING BAD! triplerc Lumina 3 06-01-2006 08:02 AM
bought a 89 iroc, 305 tbi. wont run tacoma man. Camaro Discussions 5 02-16-2005 05:38 PM
89 350 TBI running bad. TopDogg C/K 1 02-21-2004 10:15 PM
