Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-08-2011, 09:21 AM
rmil rmil is offline
Exclamation Serp. belt help......
I replaced the serp belt on my 2001 Impala, but it jumps off the pulleys every time I try to start the engine, even replaced the tensioner and pulley, thinking that was the problem....any suggestions?
Old 07-08-2011, 11:52 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Serp. belt help......
Did you replace the belt exactly as shown ( for belt routing ) on the decal on the radiator support ?
" Sometimes I grow so tired "
Old 07-08-2011, 01:15 PM
Question Re: Serp. belt help......
I followed the diagram, and there is what seems to me, plenty of tension on the belt....however, the pulley on the tensioner is not in line with the belt....it's 1/2 way on.....this is how the old belt was before I replaced it, but does not seem right. I also do not see a way to adjust the pulleys to better line up........Totally lost right now!
Old 07-08-2011, 02:38 PM
oldblu65's Avatar
Is this the 3.4 or 3.8 engine ?
Old 07-08-2011, 02:39 PM
jdl jdl is offline
Do the pulleys line up with each other, they should. That tensioner should line up, in my opinion. Maybe there is a spacer missing?
With the belt off, no pulleys froze? The pulleys don't wobble or anything?
Old 07-08-2011, 04:38 PM
It's the 3.4....and all pulleys spin freely, no wobbles, But they do not all line up exactly. They are close (within 1/4 inch or so) but the tensioner pulley only rests on 1/2 or less of the belt (that is how it was on the old belt also) but the old belt ran without jumping off??
Old 07-08-2011, 05:18 PM
procaddytech procaddytech is offline
Check to make sure the power steering pulley is flush with the pump shaft where it presses on and see if the balancer is separating.
Old 07-08-2011, 06:51 PM
everything looks good, pulley is tight against the power steering pump, and spins freely....
Old 07-09-2011, 08:17 AM
JohnT396 JohnT396 is offline
I had a similar problem and the problem was the idler/tension pulley. Bad bearings were causing the belt not to track properly. Good Luck
Old 07-09-2011, 09:26 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Have someone else start the engine while you watch the pullies turn to see which is causing the belt to jump.
Did you make sure you got the right belt for your engine?
Did you compared it to the old one to match their lenght?
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
serpentine belt help...please suzuki19 Cavalier Problem Diagnosis 2 07-10-2011 06:15 PM
99' Ram Quad Cab -I Need Seat belt Help PLEASE!! nrosssr Ram Pickup | Ram SRT10 0 03-30-2009 05:42 PM
help with serp. belt installation on a 2k rodeo evilcrownvic Rodeo | Passport | MU 2 04-08-2005 10:38 AM
how do i get the serp. belt off a 97 cutlass w 3100 v6 bullinachinashop Cutlass Series 2 09-01-2003 07:29 PM
