Old 10-31-2004, 06:08 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Question Quick carbon fiber ?
I have a quick question, does the decal have to be applied to a painted surface or can it be applied to bare plastic? Sorry for the lame question. Feedback please!!!
In Progress
Old 10-31-2004, 06:47 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: Quick carbon fiber ?
It can be applied to bare plastic just like any other decal.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 10-31-2004, 06:48 PM
freakray freakray is offline
AF Modelrater
Most C/F decals are transparent to a certain degree, the underlying color will make a difference to the final look, unless you're applying the decal to a grey or black plastic, I would recommend painting first.
AF User Guidelines
Old 10-31-2004, 08:56 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I've actually found that decals don't stick near as well to plastic as they do to paint, though others may have a different experience. I'd go ahead and paint, just to be save. A nickel on paint will save you a few dollars of CF decal if it fails.
Old 10-31-2004, 10:11 PM
Vric's Avatar
Vric Vric is offline
deprend of the brand. some cheap CF decal are transparent and need flat black base color
Old 11-01-2004, 09:56 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Decals are designed to go on painted surfaces. While you can apply them to raw plastic, they will not adhere very well and you run the risk of having them chip very easily. - Mark
Old 11-01-2004, 10:28 AM
rsxse240 rsxse240 is offline
NEVER!!! NEVER!!! apply decals to flat paint!!!!!!
doing so will leave air between the textured surface of the paint and the decal, thus causing it to "silver" and the decal won't adhere so it will flake off. best bet is to either clear coat the flat color, apply the decal then shoot it with flat or semigloss if you are going for a non reflective surface, or gloss respectively. and make sure to use a good decal solvent, and decal setting solution while aplying the decal and clean everything up before you put the clearcoat on.
I hope this helps you in your modelling endevors.
_Ken
Old 11-01-2004, 11:08 AM
Vric's Avatar
Re: Re: Quick carbon fiber ?
_Ken
half true. Yes, it's bad to use decal over flat paint, and yes it will silver. but since CF decals usually cover a full surface and they don't have the transparent part on it, there will be no visible silver.
All my CF job have been done over duplicolor black primer (which is flat)
Old 11-01-2004, 11:40 AM
I have used a really strong decal solvent that actually made the decal melt into the paint on some railroad cars. I don't remember what brand it was though.
I am suprised that the CF decal doesn't flake off of the flat paint. I can see how it would work for you on the large surface of like a hood or decklid, but like interior panels, or whatever may not work so well.
Old 11-01-2004, 12:02 PM
proosen's Avatar
proosen proosen is offline
I was lazy once and put the decals right on the plastic, they curled of shortly after.
Niclas
Old 11-01-2004, 02:00 PM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
Don't mean to hijack this thread, but is it alright to apply decals over primer? There are some areas on my project which i dont have the paint for but primer will be there.
Old 11-01-2004, 06:38 PM
if you are going to paint it, then why put decals on it first?
Old 11-01-2004, 11:37 PM
MidMazar's Avatar
thanks for all the responses, i decided to paint it just to be on the safe side, wow i feel like af is a family.
In Progress
Old 11-01-2004, 11:41 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Ahh no wonder the CF on the wing of my Silvia came off soo fast! it was on bare plastic!
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
