Go Back   Automotive Forums Car Chat > Ford > Taurus | Taurus Wagon
Old 03-07-2004, 08:41 AM
baxp baxp is offline
Bad ignition switch
As near as I can tell the pin on the bottom of the switch broke. Now the key will not turn the car off. I have to disconnect the power from the coil, then the battery. Does someone know where I can get a diagram of the steering column? Or does someone know how to fix this problem and replace the ignition switch?
Old 03-21-2004, 01:37 AM
jim12051 jim12051 is offline
Send a message via Yahoo to jim12051
Re: Bad ignition switch
I recommend you purchase a chilton maual for your car it will show you how to remove the ignition switch
Old 05-13-2004, 10:22 PM
jeremy2126 jeremy2126 is offline
remove lock cylinder
you can buy a new lock cylendar(ignition real cheap at the store. once you press the button just pull on it. it'll just pop out.
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 09:41 AM
Another Bad Ignition Switch??? grandma carol Grand AM 3 07-12-2006 06:39 AM
FD bad ignition switch? feedthafire RX-7 0 04-24-2006 08:27 PM
Will Bad Ignition Switch kill running engine? Mojo33 Riviera 2 10-24-2005 03:21 AM
98 Blazer - Bad Ignition Switch? rasmith527 Blazer 7 10-12-2005 09:05 PM
