Old 01-02-2002, 12:06 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Engine not heating up?
My LeBaron's engine is not holding heat. It heats up but as soon as I turn on my heater the engine temp plummits. Also the temp usually doesn't get to normal. The only thing I can figure is this:
Last weekend my alternator belt snapped and the engine overheated. I was driving home and didn't notice something was wrong until the heater was blowing cold air and when I looked at my temp guage it was almost to the top. So I pulled over and found the belt shredded up. I let it cool down and then drove the rest of the way home. I was just recently able to get the belt back in. All I can figure is that the thermostat is stuck open and just keeps letting water and coolant in.
Does anyone have any other theorys on what may be causing it to not heat up?
Old 01-02-2002, 12:12 PM
spnx's Avatar
spnx spnx is offline
The first thing I would suspect and replace just for the heck of it is the thermostat.
They're cheap, and shouldn't be over $10 anyway.
Old 01-02-2002, 12:14 PM
Polygon's Avatar
The Red Baron
Ya' that is what i am going to do after work. I am just hoping that it is not something else.
Old 01-02-2002, 04:20 PM
Andre the Giant Andre the Giant is offline
I had the same problem with my Thunderbird (engine didn't warm up) just before the head gasket let go. (I think you responded to my posts) And now, the loaner '93 Talon TSi AWD I'm driving is doing much the same thing. WTF? I don't drive that hard.
Anyhow, replacing the thermostat is a good place to start. I hope that's all you have to do. Good luck!
"Anti-freeze?!? Out of the TAILPIPE?!? This can't be good!"
Old 01-02-2002, 05:34 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Yeah, good luck, man, and please tell us the solution.
Old 01-03-2002, 10:00 AM
Polygon's Avatar
The Red Baron
Yep, took of the thermostat last night and it had failed open because of the overheat. Changed the thermostat and everything is back to normal now.
Thanks for the input guys.
Old 01-06-2002, 12:56 PM
Steel's Avatar
Steel Steel is offline
my engine in my pathy is doing that, except ive already changed the thermostat like twice already, but the engine is still running cold.
i dunno if its just another faulty thermostat stuck open or what. but that truck never ehats up, and being in 10 dgree weather, it really sucks.
help!
Old 01-14-2002, 08:50 AM
MIC 80 MIC 80 is offline
Lightbulb
:sun: Hay every one, if you motors don't heat up with a new thermostat you might try runing a higher temp thermostat, so that the coolant must get hotter to get it's flow, this is a good idea if you live in a cold area BUT BE CAREFUL putting a thermostat in that the temp rating is to high on will couse the motor to over heat check with your radiator shop to get a idea where to start from.
98 engine worn heat up addd673 Venture 9 02-04-2011 10:02 PM
Choke Coil Not Heating Up shawn_dh Problem Diagnosis 3 01-12-2008 04:39 PM
2002 envoy not heating up lannygray Envoy 1 11-23-2007 08:01 PM
engine won't heat up bdrag Rendezvous 6 01-30-2006 08:56 PM
Engine won't heat up iamcosmos Tacoma 2 11-17-2005 08:29 PM
