Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 03-15-2004, 06:39 AM
bdrag bdrag is offline
engine won't heat up
Hello all. I've got this check engine light that is on and it turns out that it is a 'coolant temperature low' warning. The engine won't heat up while i'm driving but will heat up in the garage. I am in michigan so it gets pretty cold. The thermostat seems to work fine.
Old 03-20-2004, 05:24 PM
munson munson is offline
Re: engine won't heat up
As to be the thermostat.
It's the only thing that open and close to let or not the water flow.
Old 03-22-2004, 10:28 AM
Turns out the thermostat was bad. It cost an ungodly 240 dollars to replace. What a joke.
Old 03-22-2004, 11:36 AM
Welcome to the buick owner circle.
And wait t'ill you'll have a wheel bearing or tie rod defective
or a knocking 3.4 engine.
Old 06-28-2004, 01:18 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
240 bucks for a thermostat, what?
My Mopars
Old 01-29-2006, 06:32 PM
KillerKeller_jr's Avatar
KillerKeller_jr KillerKeller_jr is offline
You could have done it yourself, part cost about $8 from a parts store and would only taken 1 hour to replace.....did you get ripped off.
Old 01-30-2006, 07:56 PM
Unhappy Re: engine won't heat up
2 things : 1st: Electric rad fan stays on (what I doubt)
2nd :Thermostat from previous reply : only the thermostat open & close, and yours stays open
You proved it by saying; when driving outside rad breath fresh air and cool off too much and when inside rad breath warmer air.
Too bad the thermostat is hidden under the crossover exhaust that you have to remove to get the thermostat out (costly repair) for a cheap part
