Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 02-27-2004, 10:46 PM
abombb abombb is offline
Question How can I remove the decals on my accord?
I have a 2004 honda accord. I need to know how to remove the honda and accord decals. I know they are just glued on, anyone know how to safely remove these? Thanks.
Old 03-08-2004, 10:22 PM
accordztech accordztech is offline
Send a message via AIM to accordztech
Re: How can I remove the decals on my accord?
glued...if u want to take it off cleaner, get a blow drier and heat it up and then a cloth under a flat head and then peel away....
the H i think is pinned, it will pop off
sorrie for a late reply but automotive forums isnt the best out there, plus moderators dont do shit here.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 04-07-2004, 08:41 PM
92accordtx 92accordtx is offline
you can also take a blow dryer to it, heat it up. take some floss or fishing string/wire and slowly put it under and work it underneath the decals. after your done, carefully take a razor blade to the glue and then make sure u use like goobegone or sumthin like that... wash ur car after..wax a lot...too.
Old 04-10-2004, 02:53 PM
jajimo's Avatar
jajimo jajimo is offline
The way Honda described it is exactly as the above (although the blow dryer isn't always necessary). Beware! Do not attempt to use a flat head screw driver or other sharp objects to remove the glue! If you do (like I did) you will likely scratch the hell out of your paint. You may wish to try Isopropyl Alcohol, I found it works pretty well. Avoid nail polish remover or anything with acitate however, that will fuck up your clear coat!
How do you remove the spoiler from the hatch? Sonic Eclipse Exterior and Wheels 3 10-08-2009 11:35 PM
Can somebody tell me how to remove the rear wiper blade? el_dasensai Rodeo | Passport | MU 1 08-17-2005 10:34 PM
how to remove the plastic cover outside the gauges Deepblue626 Accord/TSX/Accord Hybrid 4 02-22-2004 10:36 AM
How to remove the window motor/regulator from a 92 accord? jtm1275 Accord/TSX/Accord Hybrid 11 07-01-2003 09:02 PM
How to remove old decals? Davoaldo Car Modeling 5 06-02-2003 12:52 PM
