Old 03-09-2004, 10:59 AM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Installation of short shifter
hey I bought a short shifter froma member awhile and I wasn't very sure on the installation...it didn't have any rubber or anything and so I just went to Lowes and bought some rubber washers and put on it. Although now it seems like it's hard to get into gear and so I'm trying to work it out. Here's a pic of the shifter I have.
Let me know if the rubber washers were necessary or not
thanks Brian
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 03-09-2004, 11:57 AM
Re: Installation of short shifter
seeit looks like a bearing there where the bolt goes through
Anyone?
Old 03-10-2004, 09:29 AM
Old 03-10-2004, 02:46 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
There should have been a rod that goes through that hole, and a polyurethane bushing for each side of it.
Old 03-11-2004, 01:08 AM
SenseiAccord SenseiAccord is offline
supposedly installing a short shifter is like the step after installing an intake... but then again it took me an hour to install my intake so im not sure how to install a short shifter. All i know is it is a 2 man operation. Need to take apart dash around the shifter and unscrew the bolt(s)? connected to the shifter. But i dunno...
Old 03-11-2004, 09:33 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
yes the busings on each side are required, make sure u tighten em down good, but not to hard, because it'll be really hard to shift if you do... (that's what i did) with the kit that i bought i had to mess around with the heat shield a bit, but it wasn't really a big deal.... you'll want to keep all your stock pieces handy incase the kit didn't include something that you'd need... if you've got any questions i'll be happy to answer em
i did the kit on a 93 integra rs
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-12-2004, 09:53 AM
well once again...you were right...I e-mailed the person selling it and asked and they said it came with bushings so i just ordered one from them. Oh well only 20.00 and besides I've already got the shifter installed I just need to put bushings on the side. Thanks everyone.
BTW Delerious I think you are supposed to tighten everything on this installation to 16lbs. This too I have to fix. Sometimes I'm just too strong for my own good. hehe lol
Old 03-12-2004, 04:11 PM
DeleriousZ's Avatar
yeah.. i don't own a torque wrench so i just kinda tweaked with it till i got it right,.... didn't take too much work and it was well worth it
how to install short shifter? Civic_D16Y5 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 06-26-2004 03:57 AM
Installed short shifter...problems! T!mmy Engineering/ Technical 32 01-02-2004 06:13 PM
install short shifter 4g4d_getone '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-12-2003 12:58 PM
installing short shifters esko1269 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 11-21-2002 06:36 PM
