Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 03-31-2001, 06:15 PM   #1
cathandler
Question
My '96 (standard model) suspension seems to be running out of gas and I was wondering what the best non-adjustable shock would be for the stock ride height. I read about using Bilstein's P10 Primera solution but apparently it's vaporware wrt using it on the G20. I'm not looking to spend an arm and a leg, either. Would the KYB GR-2 be the best solution for this application? Thanks in advance...
cathandler is offline   Reply With Quote
Old 04-20-2001, 02:09 PM   #2
jburnham
KYB AGXs?
I got the AGXs for my '91 and will be running them with the stock springs. I think they were ~$450. How much less are the non-adjustables?
jburnham is offline   Reply With Quote
Old 04-20-2001, 02:44 PM   #3
Nismoboy1
Nismoboy1's Avatar
Send a message via AIM to Nismoboy1
I think the GR-2's are a direct OEM replacement shock, I think correct me if I'm wrong.
Check www.tirerack.com they have the GR-2's there for about $250.They also have the AGX's there for around $400.
The AGX's are adjustable from Street(soft) to Race(hard). Both shocks should work fine with stock springs or aftermarket lowering springs, but no more than a 1.5 inch drop for the AGX's, they perform their best in between their.
You also might check with www.groupbuycenter.com they have a group buy their ending 4/25/01. The AGX's for the P10's are $370 shipped in the "continental u.s." plus they're dealing with www.coximport.com which is giving it a "limited" lifetime warranty, whatever that means, you should probably call them lol so good luck, let us know how it turns out.
John H.
2001 Infiniti G20t - Aspen White Pearl
For Sale: 18" Gold Axis Se7en's and Eibach Pro-kits also for a G20 P11. Check the Infiniti G20 Classifieds Here
***My G20 - Click Here***
Nismoboy1 is offline   Reply With Quote
Old 04-26-2001, 12:37 PM   #4
cathandler
AGX on stock springs
Got in on the group AGX buy (thanks for the heads-up!) - they shipped same day by FedEx and should arrive Monday or Tuesday. Any advice on what setting I should start with? My wife put really numb tires on (Michelin MXV4 Plus - yuck.)
Old 04-26-2001, 12:54 PM   #5
Nismoboy1
Nismoboy1's Avatar
No problem, you got yourself some really good shox, especially for the money. Not 100% positive but from what I've read that on setting 1 the AGX's have about 15% less dampening then stock. It's just a matter of preference. I'd start with 1 all around and work your way up on the stiffness until you get a ride that your comfortable with in terms of ride quality and performance. You probably want the rears a little stiffer to reduce some of that factory understeer. Say 1f/2r and up from their. or whatever you want. good luck
John H.
'96 G20 Factory Alarm is made by Alpine? NismoPC Audio/Security 1 11-11-2005 07:30 PM
Tire and rim size for G20 with stock suspension oakfan Suspension 0 11-26-2001 02:17 AM
OEM '96 G20 Panasonic receiver speaker out or line out?? NismoPC Audio/Security 6 11-24-2001 02:50 PM
'96 G20 Factory CD player upgrade amp NismoPC Audio/Security 0 10-07-2001 06:18 PM
'91 intake cam in a '96 G20 NismoPC Engine 2 07-17-2001 11:31 PM
