Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-05-2003, 08:08 AM
badger5 badger5 is offline
A/C compressor bracket 97 'burb
I am looking at replacing the intake manifold gaskets on a '97
suburban. I cannot figure out how to get the A/C compressor
bracket loose from the block to reach the front manifold bolts.
I see two bolts through the bracket to the block and a thin stud
with a nut. I loosened the two bolts and it didn't move. I loosened
the nut on the stud and it still didn't move. What am I missing?
Also, what is the purpose of the stud/nut? bracket alignment?
Old 01-07-2004, 07:44 PM
axle05 axle05 is offline
a\c bracket
i hope that youve gotten it loose by noe,if not you shouldent try doing intake gaskets,no offence.there are 4 bolts (1 of those is the stud)
2 upper,1 stud and nut and 1 lower (to the left of the power steering pulley,after removal pry(carefully forward to clear righthand bolt of manifold.(i hope youve removed a\c compressor first. note properly trainrd tech would complete entire intake job in under 3.5 hours(gravy job)hope this helps
Old 01-13-2004, 11:27 PM
Thanks axle05. It was the low bolt I missed. I settled for
retorqueing the intake manifold bolts using a crow foot wrench
to get the front bolt under the A/C bracket. Seems to have
stopped my coolent leak for now. I'll keep an eye on it and
maybe go for the gasket replacement when it not so dang cold
out.
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 05:45 PM
95 Lumina A/C Compressor Noise pete029 Lumina 1 05-19-2009 04:28 PM
SOHC A/C Compressor Bracket GrimL3 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 06-15-2006 10:54 PM
Replacing A/C compressor bracket ?? mdtje Z3 2 03-14-2006 11:56 AM
a/c compressor bracket sir2545 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-20-2005 12:08 AM
