3KGT at 117k miles
i got my '94SL about 3 months ago and love it, but my heads are bad and i need to get them replaced. i'm getting them from www.3kgtmotorsports.com i was just wondering what other kind of engine parts the 3kGT might start needing to be replaced. my clutch seems to be sticking a lil, atleast i hope it's just my clutch and not my tranny. so yeah, at 117k miles, what parts should i start replaceing?
The 60k service, for the second time. Since your swapping the heads your alreadying doing most of the work. Also replace the oil pump and watch your turbos's
Re: 3KGT at 117k miles
Do the 120K service....
-Engine Oil and Filter (Change) -Timing Belt and Balancer Belt -Drive Belt (Inspect) -Air Cleaner Filter (Replace) -Engine Coolant (Change) -Spark Plugs (Replace) -Spark Plug Wires (Inspect) -Distributor Cap and Rotor (inspect) -Valve Clearance (Inspect and adjust as required) -Fuel System -Fuel Tank Filler Tube Cap -Fuel Hoses -Manual Transaxle/Transmission Oil including the transfer case -Tire Rotation -Disc Brake Pads, Calipers and Rotors -Rear Brake Drums, Linings, Cylinders and Parking Brake -Brake Hoses -Ball Joints and Steering Linkage Seals -Drive Shafts and Boots -Evaporative Emission Control System -Exhaust System- Connection at Muffler, Pipes and Converter Heat Shiels (Inspect and service if required) That should keep you pretty busy.
[/url]
