Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 12-13-2001, 10:51 AM
manzano manzano is offline
Cool relative horsepower calculator
Hey all
Ever wonder why your car seems to pull harder in certain weather?
Here's a link to a site where you can punch in the variables and find out just how the weather (and altitude, if applicable) is (are) affecting your engine's performance.
http://home.sprynet.com/~rshelq/calc_hp_dp.htm
Just check your favorite online weather source to get the info you need, and this calculator will show you current relative HP (100% being baseline)
It's really cool, and you'll be amazed how baro pressure and humidity (dew point) can influence power.
Cheers,
Manz
Old 12-13-2001, 11:32 PM
T4 Primera T4 Primera is offline
Hey thats cool. Do you think it'll work for turbo applications i.e. input boost pressure and various temps etc?
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 12-14-2001, 09:00 AM
T4,
Yea, it will work for turbos.
Atmospheric pressure at sea level is 14.7 psi. That's (1) atmosphere.
If you are running 7.3 psi boost, it's like you stuck the weight of another 1/2 atmosphere on top of your car.
So, divide your PSI boost by 14.7 and get you multiplication factor you need
7.3 / 14.7 = .5
so you have in effect created an atmospheric pressure (1) + (.5) or 1.5 times that of normal pressure at sea level.
So get the barometric pressure and multiply times 1.5
If baro pressure is 30.00, your adjusted (boosted) baro pressure will be
30.00 * 1.5, or, 45.00
and remember, the intake temp will be higher due to compression, so raise the ambient temp some. As to what amount, it depends on if you have an intercooler, air temp, etc. So unless you have a temp sensor that gives you temp in f or c, you'll have to guess.
If you don't have any idea, enter outside (ambient) temp * 2.
Now you've got everything you need.
Chevy Cavalier 2001 Cooling System Problem getwilde Cavalier Problem Diagnosis 6 09-02-2011 09:02 PM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 07:32 PM
How to increase horsepower? matt9214 Engineering/ Technical 1 09-09-2009 09:03 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
