Old 08-24-2003, 01:02 PM
GZusREVolution GZusREVolution is offline
Grim Tranny Reaper (repair)
The trans in my Accord started slipping horribly yesterday while driving up and down some winding hilly roads. I pulled over, checked the fluids and let it cool down. When I left the gas station it continued to act up, although I was able to get it home by babying the pedal (appr. 25 miles). The car has 79,000 miles (I put 4000 on it since February when I bought it) and the tranny has sometimes shifted a little hard but never actually slipped until yesterday (heard that was common). Should I change the filter and fluid.....add some tranny goober...tranny over-haul kit....auto tranny selector cable.....call a funeral home ??? The fluid still maintains its shade of red, but it definetely smells burnt.
All comments and advice are appreciated...(its kissed, isn't it?)
Old 08-24-2003, 02:44 PM
BullShifter's Avatar
BullShifter BullShifter is offline
You could try changing the transmission fluid, not a full flush because this could make things worse than they are. The most auto trans work I ever do is R&R - let the trans shops take care of rebuilding. If it was manual it would be a different story. IMO its cheapier to install a rebuilt unit with Warranty that it is to rebuild an auto unless you are a transmission specialist.
Hilly roads can tear up tranny's
Serpentine Belts & Tranny Fluid Don't Mix!- HELP! Alphabravo Caravan | Voyager 9 10-18-2009 04:47 PM
My tranny is locked/jammed, I can't shift it out of gear. Help please! danm1985 Engineering/ Technical 2 08-24-2009 12:36 AM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 10:19 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 03:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 04:41 PM
