Old 12-03-2011, 07:36 PM   #1
badgerfisher
Front wheel bearing replacement
I have decided that my front passenger wheel bearing needs to be replaced on my 98 cavalier 2.2L. After reading this site and other references I have found that the procedure is as follows:
- Loosen lug nuts and loosen/remove 30 mm cv axle nut
- Jack car up on stands and engage e-brake
- Remove wheel
- Remove brake caliper and rotors
- Remove the 3 T-55 bolts
- Use slide hammer to get hub assembly off of axle
- Place seal into back of hub and bolt back onto axle
If I have something wrong please let me know.
Also, I have heard different opinions about whether or not it is necessary to detach the controll arm from the ball joint. Could someone comment on this?
badgerfisher is offline   Reply With Quote
Old 12-03-2011, 07:44 PM   #2
badgerfisher
Re: Front wheel bearing replacement
Also would someone be able to verify these torque specs?
t55 bolts - 70 ft/lbs
axle nut - 180 fl/lbs
Old 12-03-2011, 10:52 PM   #3
gmtech1
gmtech1's Avatar
No need to seperate ball joint to replace the hub on your car. The torque specs you have look correct.
gmtech1 is offline   Reply With Quote
Old 12-04-2011, 09:28 AM   #4
maxwedge
A990 racer
Check the axle nut, seems high, I remember about 135.
Old 12-04-2011, 09:41 AM   #5
gmtech1
gmtech1's Avatar
Found them,70 on the hub bolts is correct. The axle nut is 144lbs ft.
Old 12-04-2011, 09:55 AM   #6
jd-autotech
yeah but i wouldnt set the e-brake.although saftey first maybe just chock the rear wheels unless u do use ur e-brake on a regular basis, be cause if u dont and apply the e-brake for the first time in years there is a good chance the cables will be rusted and wont release costing u more time and money
jd-autotech is offline   Reply With Quote
Old 12-09-2011, 10:18 PM   #7
badgerfisher
Thanks everyone. Changed the bearing today and fixed the problem.
Front wheel bearing replacement BoWhite Montana/Montana SV6 6 12-07-2005 07:24 PM
Front Wheel Bearings Replacement? sbursik Crown Victoria 4 04-14-2005 08:23 AM
Front Wheel Bearing Replacement markf C/K 3 09-12-2004 01:17 PM
front wheel bearing replacement gnailuh Off-Topic 0 03-17-2004 09:35 PM
