95 Windstar Ignition Problem
Having a problem with my wife's Windstar that's puzzling me. She called me on Friday from Wal-Mart and said that the car wouldn't shut off. I wasn't very far from her, so I went to look at it. I could tell that nothing was moving when turning it into the off position. It'll start, but won't shut off, I initially thought it was the cylinder. I replaced it yesterday and that turned out to not be the problem. Next on the assumption list would be the ignition switch itself, but I'm a little wary of that now. I went out and put the cylinder in the off position and the steering wheel won't lock. Does anyone know if the switch is responsible for locking the steering wheel? I suspect not from the looks of it, anybody got any other ideas what it might be?
1995 Windstar 3.8L 2001 Dodge Ram 2500 5.9L Gas Burner 1986 VW Golf 1.6L Diesel |
Re: 95 Windstar Ignition Problem
It is as I feared guys, it's the actuator that's broken inside the steering column. I've got everything off of it. Now I have to remove the entire steering column from the car and disassemble it to get to them. There's actually 2 of them and they're joined together by a pin.
Okay Wiswind, here's a couple more for your scrapbook. First, the nightmare!
http://s1226.photobucket.com/albums/...t=100_5001.jpg Here's the culprit, notice that the actuators are in fine shape, it's the pin that's missing. http://s1226.photobucket.com/albums/ee406/uzzo2/?action=view¤t=100_5001.jpg#!oZZ2QQcurrentZZ http%3A%2F%2Fs1226.photobucket.com%2Falbums%2Fee40 6%2Fuzzo2%2F%3Faction%3Dview%26current%3D100_5002. jpg Here's the procedure: With the tilt wheel there is a stiff spring located on the bottom of the column, it takes a small spring compressor to reinstall the spring. Here is the procedure to remove the steering column, and the dis assembly of the column to replace the actuators, this procedure is from the Ford [COLOR=green ! important][COLOR=green ! important]Service [COLOR=green ! important]Manual[/color][/color][/color], This is all there is out there so the diagrams are the only ones I have access to, hope this helps. CAUTION: Do not remove the steering column, steering wheel (3600) , and air bag module as an assembly from the vehicle unless the column is locked to prevent rotation. Lower end of steering shaft should be wired to prevent the steering wheel from being rotated and causing the air bag sliding contact (14A664) to become mis-indexed. [COLOR=green ! important][COLOR=green ! important]Steering [COLOR=green ! important]Column[/color][/color][/color], Tilt Removal WARNING: THE [COLOR=green ! important][COLOR=green ! important]ELECTRICAL[/color][/color] CIRCUIT NECESSARY FOR AIR BAG SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY (10655) AND A BACKUP POWER SUPPLY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY POSITIVE CABLE MUST BE DISCONNECTED FOR A MINIMUM OF ONE MINUTE TO DE-ENERGIZE THE BACKUP POWER SUPPLY PRIOR TO REMOVING ANY OF THE AIR BAG SYSTEM COMPONENTS. NOTE: All components of the steering column are assembled with fasteners which are designed to prevent loosening due to vibrations associated with normal vehicle operation.
Steering Column Disassembly
Assembly Reverse disassembly directions. This job calls for 3.5 hours shop time, if I had some extra money on my hands. I would've GLADLY paid someone for that labor. I can promise you that I'll have a lot more than that in it by the time it's all said and done. The parts will be here in the morning. It'll be a damned miracle if I get it all put back together and it works right. If you want, we can change the subject as well to reflect the actual problem.
