Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-28-2011, 04:39 PM
dhop11 dhop11 is offline
any ideas??
2003 malibu no lights on pass lock system never seen one. fuel pressure good,alternator good out put, never a check engine light, new plugs wires, fuel filter, air filter, fuel injectors cleaned. no the problem sometimes maybe 6 times per month on regular driving this car will shut off while driving sometimes while setting still at ilde no stuttering or nothing just shut down. driving 45 mph gauges went crazy for a second car shut off and then back on all in about 8- 10 seconds? driving 35 cut shut down nothing came back on key removed restated instantly?? any ideas??
Old 07-29-2011, 10:13 PM
stripe stripe is offline
Re: any ideas??
Any horn honking?
Cheers
Stripe
Old 07-29-2011, 10:46 PM
Re: any ideas??
no horn honking
Old 07-30-2011, 11:06 AM
slls slls is offline
Re: any ideas??
Could be electrical part of ignition switch, not key.
Old 08-01-2011, 12:46 PM
thusted thusted is offline
Re: any ideas??
i had a similar but not exactly the same problem - car would run fine, but not restart when warm - would wait a while, then it would start and run fine. Turns out the ignition relay was failing when it was warm - maybe your relay is failing after being energized for a while.
That being said, a bad relay might not account for the gauges to spike then go dead, but a bad ground might.
good luck
Todd
(not an expert)
97 Malibu 3.1 147k
Old 08-01-2011, 02:09 PM
Re: any ideas??
my mechanic today said no codes in the computer except old abs codes.. so he has had the car all wekend and it did it with him a few times he said he has seen similar instances where the crank shaft sensor is cracked and when hot it swell and oil enters the sensor component and causes iratic problems but he still is not sure, so he suggested we try that 1st so 31.00 for part 40.00 labor and we will see tonight...
Any idea if any other struts fit the 96 MX3 tookalook MX-3 0 07-12-2009 08:31 PM
Does any one have any ideas? kingweevle Pick-Up 7 11-11-2005 07:56 AM
Any Transmission experts? Shifting Problems, Any ideas? browserealty C/K 2 06-29-2005 12:36 AM
idea on how to save $ on gas.. any ideas on how to make it work??? dmorlow Aurora 15 06-20-2004 04:57 AM
