Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 06-08-2011, 01:40 PM
phil-l phil-l is offline
Any PCM replacement: Your experiences/suggestions?
Hi all -
Some of you have followed my intermittent/heat-related low-voltage problems here:
http://www.automotiveforums.com/vbul....php?t=1063344
After yet more research and testing, I've concluded I don't have a bad alternator.
However, one of the potential culprits behind this problem is the PCM (Powertrain Control Module, sometimes known as the ECM Engine Control Module; basically, the computer that controls the engine and some other related functions).
While I have not yet confirmed that the PCM itself is bad in my van - I did start doing some research on potential PCM replacement strategies. Some thoughts:
- I see tantalizingly cheap Windstar PCM's on eBay - but I also read warnings that PCM programming is required, both to make the PCM work with a specific vehicle, and to handle the embedded-chip ignition key security system. But the information I've seen is often vague and inconsistent. Can anyone confirm such issues from actual experience?
- I've seen on-line providers that claim they can remotely program a new PCM based on your vehicle's VIN, and other part numbers that are printed on the PCM itself (i.e., they mail it to you - so the vehicle isn't out of service for long). Has anyone used any of these services?
- Are there other DIY-able approaches out there?
Thanks in advance for any insights from the Windstar community!
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 06-09-2011, 10:59 PM
mark_gober mark_gober is offline
Re: Any PCM replacement: Your experiences/suggestions?
Originally Posted by phil-l View Post
Hi all -
Not on a Windstar, but I did purchase one of those PCMs for a girl I worked with's Town and Country, and it worked perfectly. Literally, straight from the box to the van and it fired right up. I bought it from automotivecomputerexchange.com. I actually purchased it through their ebay store and it was about $50 cheaper than they were listing it on their regular website.
Good luck.
Mark
Old 06-09-2011, 11:09 PM
Also,
PCMs ABSOLUTELY have to be reprogrammed. Your key's security info is stored on the PCM. I know from experience. I actually have a perfectly good PCM that came out of a 2001 w/ a 3.8l. I was having an OBD scanner problem and had access to that PCM from a van with a siezed motor. I pulled it and stuck it mine, turned the key and nothing. Thats because the security info on my key did not match the info on the ROM in the PCM.
Mark
P.S. Send me a PM if you are interested in the PCM and I'll make you a hell of a deal on it.
Transmission additives(slipping under load), share your experiences, please help. Kwattro Engineering/ Technical 5 03-28-2004 02:51 AM
What are your Experiences on Hallucinogenic Drugs Mr2Spyder2828 Philosophizing 48 03-08-2004 06:53 PM
Share your experience custmguru Engineering/ Technical 7 02-10-2003 01:15 PM
What's your experience of BMW? thesanguine General Discussion 1 09-13-2002 12:35 AM
