Old 03-24-2004, 09:45 PM
Kwattro Kwattro is offline
Unhappy Transmission additives(slipping under load), share your experiences, please help.
The auto trans in my 91 Supra (90,000miles) has developed a slipping issue. It revs a little between up shifts, and completely slips while downshifting under heavy load. The fluid has always been clean/regularly changed with the proper grade ATF since it's been under my ownership. Rebuilding is out of the question financially right now so I'm looking for an additive that you have experienced positive results from. I'm not expecting miracles, but a noticeable change for the better would be nice.
Has anyone tried Lucas Transmission Fix, or TransX?
Thanks!
Old 03-24-2004, 10:11 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
sounds like u have a toyota....
the upshifts are called 'flares' and the downshifts are simple an open clutch...since you have felt it long enuf to post, the plates are most likely gone and no additive will replace material.
it could be a sliver of stuff got into a clutch pack seal - no additive will fix that. could be clutch material and or bakelite has gummed up any shift valves....but only a teardown/cleaning will fix that.
what you can try to do is manually shift it, if that helps then I would suspect line pressures not rising from the throttle valve.
Old 03-24-2004, 10:41 PM
Re: Transmission additives(slipping under load), share your experiences, please help.
I appreciate the reality check. I understand the trans will need physical help in the long term, but it's not an option at the moment. A band-aid fix is about the only thing in my budget right now. Sharing any benifical experiences with additives or quick tricks would be greatly appreciated.
Cheers and thanks.
Old 03-27-2004, 11:54 AM
2 bottles of Lucas trans fix and the car is fine, for now
Old 03-27-2004, 01:14 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Lucas thickens trans fluid. If it works, it sounds as if you have an intenal fluid leak due to wea or damage.
Try just a tiny splash of brake fluid (not DOT 5 fluid) it will swell the O rings and seals in the clutch packs and can help, if those seals are leaking.
It has worked for me.
Old 03-28-2004, 01:51 AM
burnM's Avatar
burnM burnM is offline
Yeah, brake fluid worked for my '85 Caprice. Every time I would put it in reverse, it would take about 2-3 seconds to engage. Step-dad told me about this trick and told me not to beat on it for about a week, then to change the fluid.
It's been fine ever since....
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Dash and transmission problem. Electrical or Ignition Switch problem? Please help ! bdybldr2 Silverado 1 03-01-2007 06:13 PM
I Need Your Advice!!!! Please Help!!!! jgilley345 COMPLETELY off-topic 31 02-05-2007 07:31 PM
1993 Olds Delta 88 Transmission slipped into neutral on it's own. PLEASE HELP ME!!! cadauctions Eighty Eight 3 01-04-2007 05:54 PM
Transmission additives(slipping under load), share your experiences, please help. Kwattro Maintenance 6 04-13-2004 09:34 PM
Share your experience custmguru Engineering/ Technical 7 02-10-2003 12:15 PM
