Old 05-29-2011, 05:26 PM   #1
IsuzuGal
Question Having starting issues after new head install
I just had a new head put on my '01 2.2 Rodeo how do I double check to make sure both cam sprockets and the crank shaft are timed right?
Thanks in advance.
Gina
IsuzuGal is offline   Reply With Quote
Old 05-30-2011, 08:58 PM   #2
shinta
Re: Having starting issues after new head install
you should be able to put a timing light on it. but if not a local shop should be able to tell you
shinta is offline   Reply With Quote
Old 05-31-2011, 07:34 PM   #3
IsuzuGal
Thanks for your reply. There is no distributor -it's all computerized.
We're trying to figure it out on our own + it won't make it to a shop.
I did a compression test:
cylinder 1 190psi
cylinder 2 190psi
cylinder 3 185psi
cylinder 4 200psi
86 le sabre won't start after new head gasket dawnleblanc LeSabre 2 01-30-2006 12:39 PM
problems starting after new alternator install Nsparky Grand Marquis 2 09-22-2004 07:39 PM
AC went out after new head job goldbeemer 3 Series 1 09-05-2004 11:39 PM
wierd engine problem after new head gasket ethanol '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-08-2003 06:08 PM
Battery dies after new stereo installed 97 Rodeo Kayleigh Rodeo | Passport | MU 1 09-22-2003 11:40 PM
