Old 12-05-2003, 09:36 PM
ethanol ethanol is offline
Angry wierd engine problem after new head gasket
This is wierd and probably not related to the head. Put a new head gasket on a 91 Civic DX 1500cc auto trans. Ran fine. Took out on road and it ran fine for a mile or so at 20mph. Punched the accelerator and the engine died. Restarted fine and it idles fine but it will NOT accelerate. Even under no load. Even manually by grabbing the cable under the hood. Will idle for hours. Will sort of drive along at 1mph at idle on a flat. Won't pul even a slight slight grade. The choke is staying shut, but even if you open it, it still won't rev up. Though it does run a little better. Definitely loading up with fuel...lots of unburned gas out the exhaust. Engine code says "oxgen" but no other codes and this one won't repeat. Timing seems fine. Any ideas???
Old 12-05-2003, 10:26 PM
Dweezil6969 Dweezil6969 is offline
somethig is either not hooked up, not makeing full contact, or hooked up wrong. re-check everything you disconected, even unpluging and repluging if your not sure.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 12-05-2003, 11:17 PM
Hybrid1990crx's Avatar
Re: wierd engine problem after new head gasket
Any codes?
Old 12-06-2003, 12:59 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: Re: wierd engine problem after new head gasket
someone didnt hook something up...
Old 12-06-2003, 03:24 AM
cot's Avatar
cot cot is offline
i wonder if you're running on 3 cylinders
you can check that easily by CAREFULLY disconnecting one spark plug at a time from the engine to see if it makes any difference in how the engine sounds
if it sounds the same whether one of the wires is connected or not, you know that cylinder isn't doing anything for you
just a thought, kind of a general thing to check
Old 12-08-2003, 05:08 PM
Idles on all four cylinders. No codes.
My thinking is that it's a fuel problem...either too much fuel pressure ( how do you check that?) or th ethrottle position sensor is bad. No luck yet.
probs after new head gaskets philavine ES300/ES330/Windom 0 12-01-2010 08:02 AM
Overheating after new head gasket Hershball General Discussions 1 07-24-2008 06:57 PM
97 3.8L Problem after new head gaskets doubleya Thunderbird 3 09-15-2006 03:27 PM
Problems after installing new head gasket packen Grand AM 3 02-08-2006 05:07 PM
86 le sabre won't start after new head gasket dawnleblanc LeSabre 2 01-30-2006 11:39 AM
