Old 05-23-2011, 12:28 PM   #1
jsgold
O2 replacement - 2002 Cavalier
I have a 2002 Cavalier that has a bad 02 sensor(pre-cat) and it looked like a simple enough repair. However even with an 02 socket and 3/8 rachet there is not room to turn the darn thing. Will the metal coolant tube move out of the way id I unhook the rubber hose on the left and remove the bolt on it? I can't see what the metal tube connects to on the engine....not sure if it is another hose or a rigid type connector there.
I used to be indecisive, now I am not so sure.
jsgold is offline   Reply With Quote
Old 05-24-2011, 10:34 PM   #2
jsgold
Re: O2 replacement - 2002 Cavalier
Sorry folks....this is a 2.2 vin 4.
Old 05-26-2011, 08:04 PM   #3
Skippernoodle
Are you talking about the metal coolant hose that goes from the rubber thermostat hose and around towards the firewall?
Skippernoodle is offline   Reply With Quote
Old 05-26-2011, 09:40 PM   #4
jsgold
Yes, that is it. The problem is while I can get a O2 socket on it and 3/8 drive ratchet, you can't turn it as there is no room. I was wondering if a 1/4" drive would fair better or if I needed to move the hose. Car is loaned out for a few days so I can't try either right now but appreciate any advise. Looked like I had no problems.....
Old 05-27-2011, 07:38 PM   #5
Skippernoodle
If you follow the metal hose around towards the firewall there is a stud mounted to the transmission that holds this line in place. You can you remove this nut (I thinks it's an 18mm).
If not try using a longer extension and come in closer to the battery side of the car.
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 12:17 PM
2002 stratus cig lighter replacement sick_role Stratus 0 01-06-2010 09:45 PM
Replace Cruise Control Module 2002 Cavalier gbekken Cavalier Problem Diagnosis 1 05-01-2008 07:56 AM
Instructions for replacing 2002 Suburban 2002? rftoomey Suburban 2 01-11-2006 07:41 AM
2002 Cavalier Problem Tom Harner Cavalier 5 11-14-2004 12:46 PM
