Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-06-2006, 10:19 AM
rftoomey rftoomey is offline
Question Instructions for replacing 2002 Suburban DRL?
Has anyone ever changed a DRL on a 2002 Suburban? I can't imagine it would be that much of a major undertaking, but I can't find any sort of instructions for doing this anywhere. I'm not automotive mechanic savvy, but I can follow clear/concise directions.
Last edited by rftoomey; 01-06-2006 at 12:10 PM. Reason: I needed to correct the wording on the subject line
Old 01-06-2006, 12:12 PM
Correction: Subject should read "Instructions for replacing 2002 Suburban DRL?
I screwed up the subject line and tried to correct it, but I noticed that it still appears as "Instructions for replacing 2002 Suburban 2002?" should have been "Instructions for replacing 2002 Suburban DRL?"
Old 01-11-2006, 07:41 AM
BURBAN18 BURBAN18 is offline
Re: Instructions for replacing 2002 Suburban DRL?
Above each headlight there are two allen wrench looking pins remove them and the Headlight will easily come out, then you can reach behind the DRL and change the light bulb, it takes about 5 minutes. Now if are referring to the lens or the whole assemby I have not done that.
1999 Suburban
18" rims
Dual exhaust
