Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 10-01-2010, 06:37 PM
swannie958 swannie958 is offline
94 mustang gt won't run
having problems--no fuel getting to the motor. have tried replacing the fuel pumps 3 times, no luck. just replaced the fuel pump relay (the one beside the coolant reservoir) still no fuel getting thru. any tips on testing whether the fuel pump is good or bad??
Old 10-01-2010, 07:58 PM
old_master's Avatar
old_master old_master is offline
Advisor/Moderator
Re: 94 mustang gt won't run
Can you hear the fuel pump run? If not, did you check the inertia switch, fuel pump relay and the PCM power up relay?
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
swannie958 (04-13-2011)
Old 10-03-2010, 02:19 PM
Kybar Kybar is offline
turn the key over and listen for the wind of the fuel pump, Also have you changed your fuel filter? a clogged filter can stop the flow and its often overlooked
The Following User Says Thank You to Kybar For This Useful Post:
Old 04-13-2011, 11:25 PM
thanks old master and kybar for the advice. replaced the fuel pump relay, and it cranked right up. thank you so much. it really helped. you guys are great
thanks again,
swannie958
89 Mustang LX, rough idle and runs terrible. Ericdano Mustang Problem Diagnosis 2 11-07-2009 02:14 AM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 09:59 PM
2000 Crown Interceptor won't start fuel pump won't run chrisstag Crown Victoria 16 01-30-2007 04:00 AM
Mustang won't stay running matt123 Engineering/ Technical 6 10-21-2004 01:18 PM
