Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 10-17-2004, 11:15 AM   #1
matt123
Mustang won't stay running
I have a 1999 Mustang GT, bought it new and never had a problem with it. All of the sudden it will start and rapidly die. If I press the gas pedal after starting I can keep it running and it runs smooth. As soon as I let off the gas it pretty much dies right away. All ignition connections / vacuum lines look good. Not sure where to start.... any ideas? Thanks.
matt123 is offline   Reply With Quote
Old 10-17-2004, 11:29 AM   #2
-Jayson-
-Jayson-'s Avatar
Re: Mustang won't stay running
F-Found
O-On
R-Road
D-Dead
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
-Jayson- is offline   Reply With Quote
Old 10-17-2004, 02:06 PM   #3
383PhoenixAm
383PhoenixAm's Avatar
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
Re: Re: Mustang won't stay running
Originally Posted by -Jayson-
F-Found
O-On
R-Road
D-Dead
...yes
It sounds like a bad sensor, but I'm not sure I could help ya there cause I don't know what kind of loop ford uses. You'd have better luck finding a mustang loyal forum somewhere.
383PhoenixAm is offline   Reply With Quote
Old 10-17-2004, 05:15 PM   #4
sierrap615
Master Tech Wanna-be
i know zip of fords, but in general:
check the throttle body for carbon build-up, check the IAC too. if dirty, spray with sensor-safe carb and choke cleaner(even if its EFI).
if you have a multimeter/voltmeter, check system voltage.
any check engine light/battery light?
sierrap615 is offline   Reply With Quote
Old 10-19-2004, 10:18 AM   #5
RandomTask
Banned
RandomTask's Avatar
I don't think the throttle body would be loaded with carbon? But faulty MAF or TPS could be a culprit
RandomTask is offline   Reply With Quote
Old 10-19-2004, 11:09 AM   #6
psychorallyfreak
psychorallyfreak's Avatar
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
That makes sense...
Or maybe (just maybe) bad gas...
I've had a similar problem with a different car...but, damn my memory, I don't remember the problem/solution...
psychorallyfreak is offline   Reply With Quote
Old 10-21-2004, 02:18 PM   #7
Racincc85
Racincc85's Avatar
Send a message via AIM to Racincc85
F-Found
O-On
R-Road
D-Dead
spell it backwards and you get
D-Driver
R-Returned
O-On
F-Foot
It sounds like you have a bad Idle Air Control valve. Fords were nortorious for having these go bad. It sounds like it is sticking closed.
Racincc85 is offline   Reply With Quote
