Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-10-2010, 12:22 AM
wyodan59 wyodan59 is offline
yukon transmission issues
I have a transmission issue that involves the shift indicator. I had someone repair the transmission. It now has a couple problems. First the shift indicator on the dash is indicating reverse when the key is turned on. The car will not start unless you put the shift indicator in the Neutral position, Which is reverse. All the indications on the dash are off by one position. P is not indicated. R is the park position. N is the reverse, D is neutral. 3 is Drive, 2 is 3rd, 1 is second and 1st does not change. The transmission works all the gears shift and change. The real problem is the starting in reverse. I need to know what is going on? How can it be repaired?. Also there is a leak at the transmission to the transfer case. Is this a seal problem or a gasket? The leak does not get worse when it is running.. Thanks Dan
Old 12-10-2010, 08:19 AM
maxwedge maxwedge is offline
A990 racer
Re: yukon transmission issues
We cannot diagnose a transfer case leak from here, when the trans was done the case was removed so this may be a comeback on the shop? The gear selector position is also related to removing the trans. something is out of adjustment. Always post the year also.
Transmission maintenance dahirolla Venture 4 06-25-2011 08:22 AM
94 prizm transmission issues theginchico Engineering/ Technical 3 04-12-2010 07:17 PM
1989 grand marquis transmission issues Thepinkmommy Grand Marquis 2 04-03-2010 10:26 PM
Shift Issues with Yukon xl 2500 automatic speedway1839 Yukon 1 11-30-2009 11:53 AM
transmission issues. 91 buick regal 3.8 bac512 Regal 0 04-25-2009 11:58 AM
