Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-09-2010, 09:51 AM
dahirolla dahirolla is offline
Transmission maintenance
New to me 2004 Venture. 123k miles.
Transmission seems like it slips once every few days or so, mainly when I try to accelerate quickly from a stop.
What should I do to make sure everything is in great shape?
I'm mainly concerned with the transmission, but would like general input as well. I don't know the service history, but everything looks clean.
Should I flush the transmission fluid? Are there filters and coolers to inspect?
Are there engine and transmission mounts that need replacing at 100k or so?
Thanks!
Old 12-09-2010, 12:32 PM
paprius4030 paprius4030 is offline
Re: Transmission maintenance
Our 04 has this occur every now and then also. When first started in am I back down the driveway then put it in drive and if I cam too quick to step on the gas it seems to slip for a second before engaging. It only does this on the first start in the am. Dealer says everything is fine with transmission, so I just am careful not to step on the gas too fast when I put it in drive. Not sure if this is similar to your problem or not.
99 Chevy Venture Plus Extended
6/99 to 4/08
04 Chevy Venture Plus Extended
2/08 to.....
Old 12-09-2010, 10:34 PM
lesterl's Avatar
lesterl lesterl is offline
Make shure fluid is full hot.
Is fluid burnt?
Possible sticking solenoid?
KEEP TABS ON THE COOLANT FOR SHURE IT WILL BE THE DEATH OF YOUR ENGINE (LIM GASKETS)
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 06-24-2011, 02:04 PM
truc0011 truc0011 is offline
Thanks!
Any updates on this issue? I have a 2003 Montana which does the exact same thing.
Thanks!
Old 06-25-2011, 08:22 AM
j cAT j cAT is offline
Thanks!
when first buying an older used 100,ooo mi vehicle it is best to replace the fuel filter if any, the coolant/thermostat,and all the drive train fluids. with the transmission drop the pan and repalce the filter then refill with the synthetic transmission fluid which is now dexron VI...
DO NOT USE THE DEFECTIVE DEXRON III...THIS FLUID WAS FOUND BY GM TO CAUSE TRANSMISSION FAILURES!
transmission fluid change interval schri00 Neon | Plymouth Neon 9 12-29-2011 08:02 AM
98 Voyager - transmission maintenance ggratecc Caravan | Voyager 28 05-14-2007 08:17 AM
Transmission maintenance mustgo69 Tahoe 6 04-04-2005 04:52 PM
Transmission Maintenance panzees36 Escort 8 02-17-2005 11:20 PM
Transmission maintenance john m Ram Pickup | Ram SRT10 7 12-29-2004 06:45 PM
Tags
maintenance , transmission , venture
