Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-02-2001, 07:38 PM
Aoshi1 Aoshi1 is offline
Send a message via AIM to Aoshi1 Send a message via Yahoo to Aoshi1
Unhappy rough second gear
At aceleration,when the car goes into 2nd, it SEVERELY jumps, like a hard "pop" into the gear....sometimes I break the tires loose...but it only does it in second. Do I need to rebuild my tranny? Ive no experience dealing with transmissions, so any help is appreciated...
Aku-Soku-Zan
1992 G20
GroundLevel
Bone-Stock
and ready
to tune
Old 11-03-2001, 12:08 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
What type of tranny do you have? If it's an auto, maybe check the fluid level, if it's a 5-spd, do you have an aftermarket clutch? With my ACT i can break the tires loose going into second, just because the clutch grabs so hard...
Also, where in Phoenix do you live, my parents live in Gilbert, and I know all the SE-R people in and around the Phoenix area. (I'm going to school at UofA right now).
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-03-2001, 01:23 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Re: rough second gear
Mine does this too...dunno why. Check your tire pressures tho...it seems worse when they are low.
Also, its worse when the engine is cold...
Maybe the auto mount heats up? Maybe more fluid movin around in the trans? dunno...
-Brian Jones
I got a snake man
Old 11-03-2001, 01:42 AM
JustinP10's Avatar
If your auto shifts really hard, or weird, i'd check the fluid level. low tranny fluid makes an auto do weird things. I used to check mine rather frequently, as i had a slight leak, and when it got low, the tranny would act very strange.
Justin McClanahan
95 G20
Old 11-03-2001, 01:45 AM
I believe theres a hot/cold mark...but whens the best time to check it?
-Brian Jones
I got a snake man
Old 11-03-2001, 01:50 AM
JustinP10's Avatar
I'm sure when you change your oil is fine to check, as long as you don't have a major leak or anything. I'd usually check mine when it was cold, just because I usually changed my oil when the car was cold, so i wouldn't burn myself, But you should be able to check it either way, iirc there are two different ranges, one hot and one cold (think the hot was between the two notches, the cold range was actually marked on the stick, i think?)
Justin McClanahan
95 G20
Old 11-03-2001, 05:22 PM
T4 Primera T4 Primera is offline
Could be a fluid pressure problem, you may need to change the filter in the tranny oil pan. Read paragraphs 2 & 3 of this: http://www.se-r.net/transaxle_clutch/auto_lsd_info.html
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 11-03-2001, 07:03 PM
Re: Re: rough second gear
Good article. He was speaking about the Q45 having an "in-line" filter that catches this material. Did anyone find one yet for a SR20? =)
-Brian Jones
I got a snake man
Old 11-05-2001, 02:16 AM
Domo minna-san ( thanks guys)
Wow, you guys kick ss....Im gonna check into that. BTW Justin P10, Im in North Phoenix, and Gilbert is a WAYS away, but Nissan peole are hard o come by...I know lots of Nissan Haters though, like all the asses at Versus Motorsports..Assholes. Anyways, any time your up this way, give me a shout. Its always good to talk shop, ne? Late, and thankx again guys,..
Oh, aso, it is auto <!>....
Aku-Soku-Zan
1992 G20
GroundLevel
Bone-Stock
and ready
to tune
Old 11-05-2001, 02:28 AM
JustinP10's Avatar
That's cool, I actually know quite a few SE-R people up in North Phoenix. Well, Northwest kinda too. Do you know about the az SE-R list? Here's a link. AZ SE-R list You should join, there's usually meets every month or so, with little events happening even more frequently.
Justin McClanahan
95 G20
Old 11-05-2001, 02:56 AM
Aoshi, you may find this thread useful as well:
http://www.automotiveforums.com/vbulletin/t5715.html
-- Bertrand Russell
2005 Jetta 2.5 Lurches between 1st and second gear. Also sounds rough in the morning. freeups '04+ 3 01-01-2010 10:53 PM
My dads 525i peels out in second gear? Jasoncab 5 Series 1 08-06-2003 08:55 AM
Resistiance going into second gear Santas90Si '88 - '91 Civic | CRX | Wagon | Shuttlee 8 11-05-2002 06:13 PM
burst of thrust/ hard shift when auto tranny shifts into second gear ERIKbronx Maintenance 6 04-22-2002 01:36 PM
Has anyone been able to go above 65 on second gear brandonf '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 34 04-19-2002 01:33 PM
