Torque steer or what?
I have a 95 civic ex with the d16z6. Whenever im driving my car pulls to the left. I know its not the alignment, and my its not my tires because its still the same when I have them rotated. So is it torque steer from the d16 that pulls me to the left?
:flamer: :eshooter: :rocket: |
How do you know it's not your alignment? Torque steer from a d16 just sounds rediculous.
Cuz I said
I know its not the alignment because I had it aligned and they found nothing wrong with it. So I figured it might be torque steer because I was reading others posts that mentioned the D16 motors produce torque steer.
:bandit: |
all fwd cars produce torque steer, but only when you're flooring it.
if you're cruising at a regular speed, and it pulls left, it may be the road you're on, or the alignment. get your tires rotated and balanced... |
not all cars produce torque steer, you need some massive torque first, and the 80ft/lb hes putting out just aint gonna cut it.
you prolly dont have enough air in your left tire, so it grips more on the road, your alingment is prolly off, or you can be getting traction only on the left wheel, like your right is os loose gravel or something.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
1989 s13 Fastback Tein HE coil-overs sr20det swapped! JIC Magic Front and Rear Strut Bars Slotted and Cross-drilled Rotors S/S Brake Lines Pivot Lazy eye controller Blitz LM Intake Blitz D1 Spec Turbo Timer Soon to come: Sard 550cc Injectors Blitz Nur Spec Exhaust Blitz Down pipe HKS FMIC http://www.driftmonkey.com (Part Owner) |
this guys d16 is stock tho, at lest he hasnt said that its not so im assuming. and yes probably anyone with a similarly built B16, B18, B20, H22 can beat it, unless he has it in a gokart
current -84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex history: -01 R1-04 daytona 600-94 teg RS-95 teg LS -91 teg RS-92 teg GSR-94 civic CX hatch (3 times) -94 civic DX-96 civic HX-97 Accord LX-72 superbeetle -74 beetle-84 silverado-66 c10-74 maverick-78 280z -84 200sx-86 tercel wagon-95 mustang V6 |
