| Register | FAQ | Social Groups | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Maintenance problems, fixes. |
steering wheel shakes @ high speeds
my steering wheel starts to shake a lot at about 85 and higher. does anyone else have this problem? anyone know how to solve it? i think its cause of my camber, its -2.2 in front driver side. i have center caps on my stock rims. please help its annoying! :apoke:
Have your wheels balanced and get an alignment done on the front.
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
ill get my wheels balanced, i got an alignment recently, and cant change the camber.
It's not because of your camber.
Most likely it's due to the tires/wheels being out of balance. Sometimes they can actually be balanced correctly, but if care is not taken while installing the wheels, the wheels can end up ever so slightly off-center (this sounds far fetched, but it's true). Several people on the SE-R list have corrected such problems using my wheel attachment procedure: When installing the wheels, finger tighten the first lug nut while moving the wheel around slightly. Finger tighten the second nut and if the wheel moves around, move it around while tightening as well. You shouldn't be able to wiggle the wheel once the first one is tightened, and absolutely not after the second. Finger tighten the remaining lug nuts and tighten with a wrench with the wheel in the air (you won't be able to tighten them all the way by any means). Lower the wheel to the ground and torque to spec. This has been quite successful in the past. If this doesn't work, get your tires/wheels balanced again and use the tightening procedure above. If this doens't work, the problem is in your suspension. Something is loose/sloppy. It could be caused by worn bushings, worn balljoints, or worn tie-rod ends. It's even possible it could be caused by worn tie-rods, but that's not very likely.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
car into a pole...
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too. 2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite) 2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings. Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.fiamm dual air horns. |
![]() Sorry, I shouldn't joke. That sucks actually.
i had the same problem with my car.. i was getting a headache when driving long distances.. and after i got my tires balanced, it mysteriously dissappeared.. hey good luck..
kenchan.. sorry bout yo car.. dude!! buddha |
