Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 01-17-2004, 03:20 PM   #1
rsred900
High Blower stuck on
My 2000 Intrigue has 88K miles. The high blower is stuck on. I had to pull the fuse to stop it from running down. Can someone tell me what the problem is. I did pull the negative terminal on the battery, thinking that I could reset the computer. But that didn't work. (This did work when it happened before several months ago.)
rsred900 is offline   Reply With Quote
Old 04-21-2004, 09:49 PM   #2
Greekcardinal
Re: High Blower stuck on
I have the same problem. Did the rest work? How did you rest the computer?
Greekcardinal is offline   Reply With Quote
Old 06-17-2004, 02:39 PM   #3
kinzarp
I have a '99 Intrigue with the same problem. Is there a fix for this problem or just the "bandaid", pulling the fuse or removing the negative battery cable? Have you had any other electrical problems with your vehicle??
kinzarp is offline   Reply With Quote
Old 08-12-2004, 10:16 PM   #4
Lisa7195
Re: Re: High Blower stuck on
I have a 98 Intrigue with the same problem, someone on another message board told me it sounded like the blower motor module needs to be replaced haven't tried it yet just recieved the info today and thought i would pass it on
Lisa7195 is offline   Reply With Quote
Old 11-17-2004, 10:53 PM   #5
Renegade2k
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
fan Resistor
I can't be sure if this is the problem, but gm has a common problem with their fan resistors burning out and only the high speed works. I had to replace mine. it is located on the bottom of the ductwork right next to the firewall by the fan.
Warning. Don't try to change this yourself unless you are FLEXIBLE.
I had to lie upside down for a half hour while I changed it, and I still wasnt able to put one bolt back in.
Renegade2k is offline   Reply With Quote
Old 11-18-2004, 09:16 AM   #6
paulkramer
Thumbs down
GM has a common problem with EVERYTHING failing.....
paulkramer is offline   Reply With Quote
No horn and high beams stuck on Sticks21 Problem Diagnosis 7 10-30-2006 08:03 PM
2001 AWD - No High Blower timheis M Bodies 4 09-12-2006 06:01 PM
Blower stuck on mikenau Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 08-05-2006 03:46 PM
High Beams Stuck On MathGrace Accent | Verna 0 05-27-2005 08:57 PM
