Old 09-09-2006, 09:08 AM
timheis timheis is offline
2001 AWD - No High Blower
I have an 01 AWD with no high speed htr/ac blower speed. There is no voltage to the blower motor with the switch to high. I cannot find any hi-speed relay. Other than the switch, what else can it be?
Thanks
Tim
Old 09-09-2006, 08:51 PM
sreve sreve is offline
Re: 2001 AWD - No High Blower
you have to remove the washer and coolant bottles. the relay is built into the resistor assembly.
Old 09-09-2006, 10:17 PM
old_master's Avatar
Advisor/Moderator
http://www.wdautoparts.com Will drop ship, (part #DR779) to your door for $30.05 USD. The replacement module is an improved design and requires a slight modification to the evaporator housing. The module comes with detailed instructions for the modification. It's done with a dremel tool in about 5 minutes. The whole job takes about 30 minutes to complete.
Old 09-11-2006, 08:06 AM
drew300 drew300 is offline
I found the sealant GM used on the resistor/relay module ate some of the printed wiring on the board.
I soldered on replacement wire and it works fine.
A bit of trouble following the missing printed wire though.
Old 09-12-2006, 05:01 PM
Problem cured
I bought a service manual CD off Ebay and the wiring diagram showed the AC/HTR 30 amp fuse in line with the only 12v supplied to the relay when activated.
Just a fuse.
The schematic sure does make life a lot easier.
Thanks All
Tim
