Does anyone know why my 1989 Civic Dx Hatchback with the 1.5l (5 speed manual) bogs down and almost stalls at low rpms when I give it gas??? I replaced the O2 sensor, and that did nothing. I just replaced the plug wires about a month ago and that solved the problem for a little while. But now it's doing it again?? I also replaced the fuel filter and checked the air filter. Has anyone else had this trouble?
When was the last time, the timing has been checked...?
What color are the plugs, and are/were they uniform...? Are you smelling fuel/gas or seeing smoke out the exhaust, when this happening...?
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion NOS #5122, JR Liquid InterCooling System ZYDNE SECU, 450's B&M FP Set, B&M Command Flo AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods, ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI |
same deal
Hey man,
I have the same problem (with the same year/engine/tranny combo). I can't figure out what it is either! it seems to be worse in hot weather for me (I have had the main fuel relay replaced after the no-start while hot problem without any help) -Adam. |
This might sound stupid, but you said you replaced the plug wires, did you replace the plugs to, cause that could do that
KoRnSaQ |
Re: Still spitting and sputtering???????
I had that problem once. It turned out to be the distributor. Check it out.
#6 | ||
Re: same deal
Just a thought...
#7 | |
But if the ECU thought the engine was cold, it would constantly have a high idle, wouldn't it?
Saturn Stealership Technician #331 |
#8 | ||
Re: Re: Still spitting and sputtering???????
#9 | |
It went away. I had the timing adjusted the other day, I had put new plugs in the car about 8 months ago, (bosch plantium plugs). I figure that it was either water in my gas or the exhaust. My exhaust is pretty fucked up. I think the muffler is rusted out inside, I definitely have a hole in my exhaust, and I probably still have the original cat. converter.
I think that may have been the problem. But did anyone else try those bosch plug wires, OEM type? It seems that they don't cover up the top of the valve cover holes where the plug wires go into. Could water get in there? Thanks for the responses. |
