Go Back   Automotive Forums .com Car Chat > Lamborghini > Diablo
Old 11-03-2002, 08:13 PM   #1
allanf
Send a message via AIM to allanf
Twin Turbo Diablo SV
allanf is offline   Reply With Quote
Old 11-03-2002, 10:02 PM   #2
gemballa
how many hp?
Lamborghini was made to be an ALL car killer!(specially for ferrari)!
gemballa is offline   Reply With Quote
Old 11-03-2002, 10:20 PM   #3
allanf
It does not say, but it does say it will boost 1.4 which is huge boost, i think 18-20 pds, since 1.0 bar is 14.7pds. The vttt quoted something like 900hp at 15 pds. It must have extensive internal modifications, and i also know it uses a motec engine management system.
Old 11-04-2002, 11:03 AM   #4
Menu dei Motori
Click here
Menu dei Motori's Avatar
Send a message via ICQ to Menu dei Motori Send a message via AIM to Menu dei Motori Send a message via MSN to Menu dei Motori
i just know about that vttt:
TECHNICAL SPECIFICATIONS
Lamborghini Diablo VTTT
ENGINE
Type V12
Mid-longitudinal
Aluminum block and heads
chain driven DOHC per bank
Valves 4 per cylinder
Capacity 5,707cc
Bore/Stroke 87mm x 80mm
Compression 10:1
Turbos 2 Garret T4 turbos
Fuel System Weber-Marelli electronic port fuel injection
Max power 600bhp @ 6,800rpm
Max power 752bhp @ 6,800rpm
DRIVETRAIN
Transmission Four wheel drive
Gearbox 5-speed + reverse
Transfer-gear Ratio 1.59:1
Final-drive Ratio 2.41:1, limited slip
Clutch Dry single plate 10"
Gear Ratios
1st
2nd
3rd
4th
5th
Reverse 1:2.31 - 59 mph
1:1.52 - 89 mph
1:1.13 - 121 mph
1:0.89 - 154 mph
1:0.68 - 202 mph
1:2.12 - 65.5 mph
Differential Central - Viscous Coupling
Front Bevel Gear Type - Limited Slip 25% - Ratio 1:2.81
Rear Bevel Gear Type - Limited Slip 45% - Ratio 1:2.41
STRUCTURE
Chassis Steel-tubing space frame
Body Aluminum alloy, carbon fibre and fibreglass reinforced plastic
Wheels O.Z. Racing 3-piece, cast aluminum hub with forged aluminum rim
- front 8.5 x 17 inches
- rear 13 x 17 inches
Front Tires 245/40ZR-17 Pirelli P Zero
Rear Tires 335/35ZR-17 Pirelli P Zero
SUSPENSION
Front Independent unequal length control arms, coil springs, anti-roll bar.
Rear Independent unequal length control arms, 2 coil shock units, anti-roll bar.
BRAKES
Type Vacuum power assisted
Front 12.6 in. ventilated discs
Rear 12.2 in. ventilated discs
DIMENSIONS
Wheelbase 2674.4 mm / 104.3 in
Overall Length 4502.6 mm / 175.6 in
Overall Width 2059 mm / 80.3 in
Overall Height 1115.4 mm / 43.5 in
Front Track 1553.8 mm / 60.6 in
Rear Track 1656.4 mm / 64.6
Ground Clearance 143 mm 5.5 in
Weight 1701 kg / 3750 lb
Distribution
Front/Rear
40/60
Fuel Tank 26.4 U.S. Gallons
PERFORMANCE
Top speed - 600bhp 222mph
Top speed - 752bhp 255mph
and the svtt
1998 Lamborghini Diablo SVTT Specifications
General Information
Price: $259,000
Miles Per Gallon: --/-- mpg
Curb Weight: ---- lbs
Layout: Mid-Engine/RWD
Transmission: 5-Speed Manual
Engine
Type: Twin-Turbo V12
Displacement: 5707 cc
Horsepower: 750 bhp @ ---- rpm
Torque: --- lb-ft @ ---- rpm
Redline: ---- rpm
Performance
0-60 mph: 2.9 sec
0-100 mph: 6.4 sec
Quarter Mile: est 10.3 sec @ 140 mph
Skidpad: .98g
Top Speed: 200+ mph
Braking, 60-0 mph: --- ft
Slalom Speed: --.- mph
these are dates from two different sites... and i don´t know if they are correct
Menu dei Motori is offline   Reply With Quote
Old 11-14-2002, 11:41 AM   #5
jsb88
jsb88's Avatar
That is one hell of a lot of information! thank you!
jsb88 is offline   Reply With Quote
Old 11-16-2002, 07:12 AM   #6
Menu dei Motori
Click here
no problem
wasn´t too easy to find these specifications of this rare/unique car
Old 11-16-2002, 08:35 AM   #7
jsb88
jsb88's Avatar
It is very hard to find real specificatioons in the first place! Maybe we should make a website, telling the real specs of cars, and how fast they really go, with some background information too!
Old 11-16-2002, 08:42 AM   #8
Menu dei Motori
Click here
and we test them
Old 11-16-2002, 11:28 AM   #9
jsb88
jsb88's Avatar
If you properly advertise yourself, then you will get free car reviews, but you basically can only say good things about it unless you are very, very influential with a reputation to uphold.
Old 11-16-2002, 01:55 PM   #10
Menu dei Motori
Click here
the husband of my godmother (what a word!!!) has a job like that
he even tested the enzo ferrari as one one the first!
all week he gets another car! thats a cool job
his name is Georg Kacher .. he is well known in germany
Old 11-17-2002, 04:20 AM   #11
jsb88
jsb88's Avatar
That is the sort of job I would want!
Old 11-17-2002, 06:04 AM   #12
Menu dei Motori
Click here
maybe i´m gonna make a kind of apprenticeship with him
but my english must get better ..
so i probably go to england or southafrica for some time
Old 09-29-2003, 03:48 PM   #13
Stratoraptor
Stratoraptor's Avatar
Send a message via AIM to Stratoraptor
does any one know how many SVTT and VTTT Diablos were built?
Stratoraptor is offline   Reply With Quote
Old 09-29-2003, 05:00 PM   #14
jsb88
jsb88's Avatar
I think I posted a list of Diablo numbers built in which years and what models somewhere around here. Have a look around.
Old 09-29-2003, 06:09 PM   #15
hiphophomer
Banned
hiphophomer's Avatar
is it hard to find a svtt for sale?
hiphophomer is offline   Reply With Quote
twin turbo WS6 vs. twin turbo supra doodad Camaro Discussions 17 03-14-2006 09:21 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac General 31 08-10-2005 04:05 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 49 10-03-2004 11:28 AM
question about the 1278 hp Diablo twin turbo Diablo SE30 Diablo 29 09-13-2004 05:29 AM
Twin turbo Diablo blueboost Car Modeling 8 11-04-2003 06:55 AM
