Old 09-29-2003, 10:44 AM   #1
BuzzStPoint
Send a message via ICQ to BuzzStPoint Send a message via MSN to BuzzStPoint Send a message via Yahoo to BuzzStPoint
1996 remote start help
We have a 1996 lumina and want to put in Remote start for the winter..
question is this car has that stupid security chip on the ignition key.. will we have to do anything different because of this?
BuzzStPoint is offline   Reply With Quote
Old 10-06-2003, 10:27 PM   #2
weezey2u
Use a IPP03 this will temporaily bypass the vats system for remote starting, or if you wanted to do away with the vats measure the resistance with a ohm meter "one lead on each side of the chip on the key" and look under the dash by the ignition wires for a orange loom with two very small white wires then strip the loom away and cut the wires and get a resistor within .05% of your meter reading and solder the resistor to each end of the white wires leaving the ign switch out of the loop and you will be good to go but if it were me i would get the bypass because it is self learning and fool proof with very few wires to ajoin good luck hope this helps
weezey2u is offline   Reply With Quote
Old 10-07-2003, 11:18 AM   #3
BuzzStPoint
Ok next question is.
the car kits we've been looking at have alarm, remote start and auto door locks...
This car already has auto door locks. Is there a way I can install this so the remote start has control ofthe door locks? So we dont have to have two remotes?
Old 10-07-2003, 10:43 PM   #4
ponchonutty
ponchonutty's Avatar
Re: 1996 remote start help
Yes you sure can. Just grab the gray for lock and white for unlock in either kick panel. They are a + pulse wire.
Go for a DEI starter. They are awesome compared to the others. The new ones even have a dedicated wire to turn on rear defrost too.
Before you spend $30+ on that bypass, just get a good relay and a pack of resistors. I just did one the other day and had about $4 in parts.
ponchonutty is offline   Reply With Quote
Old 10-07-2003, 10:50 PM   #5
BuzzStPoint
http://www.crimestopper.com/remotestart03.html
the RS-900 Series VI
is the system I was thinking about. I did look further and looks like I will probably just use the Resisitor in the colulm.
Old 10-08-2003, 01:15 AM   #6
weezey2u
The only problem with using the resistor on the vats is you are disableing it completly and not bypassing it but it will work that way, the crimestopper is not that bad but i like the new code alarm they have improved alot over the last year and you might want to look at them but dont pay for DEI its overpriced and not that much better,all of the major brands has its ups and downs so choose wisely just whatever you do stay away from design tech products
Old 10-08-2003, 10:42 AM   #7
ponchonutty
Re: Re: 1996 remote start help
I dunno about the Crimestopper stuff. I tried to save money last winter and bought about 30 of them. I had about 15 cars with problems and 3 bad out of the box. I can not afford to have problems like that. Granted it was nice buying them for less than $50 a piece versus $100 for a DEI unit but not for the hassle. You really should look at the new Valet 562t starter. They are completely awesome. Could not believe they could get their starters any better..
Yes, I 2nd the deal about the resistor with some exception. When I work on a new car with VATS I use a resistor with a relay. When you do not remote start, the system is normal but when you remote start it clicks the relay over with the correct value. Thus, you only bypass the OEM security when you remote start it.
Now, when the vehicle has around 75k miles on it I consult the owner. See, the VATS system has one major weak link, the ignition. Those tiny little wires have to go inside the cyl. lock. They have to move when you turn the key which makes them fail over time(I know this personally on my '89 Formula). So, on recomendation from the owner, I might just go ahead and wire a resistor inline and bypassing the system completely. I live in a very rural area and car theft usually isn't that big of a deal.
Old 10-08-2003, 11:18 AM   #8
BuzzStPoint
Well thats kinda the problem,, She dont want to spend too much more than 60-65 buck on a remote start.
I with the options the crimestopper seemed to be the best deal.
Also this relay,, Could you show me where I may purchase this?
Old 10-08-2003, 05:59 PM   #9
weezey2u
just get a SPDT relay i use 40 amp then
85 should go to the ignition
86 to active out of the remote start
87 should have the resistor inline and go to one of the vats wires "with a splice not cut" then cut the other one
87a will go to the ignition side of the cut wire
30 will go to the decoder side of the cut wire
and that will bypass for remote starting and keep the vats working
Old 10-08-2003, 06:17 PM   #10
weezey2u
Here is some help with the wire colors and locations but please check each one with a logic probe before attaching wires
THESE WIRES ARE LOCATED IN THE STEARING COLUMN
B+12V= RED
STARTER= YELLOW
IGNITION 1=PINK
IGNITION2=VIOLET
HVAC=ORANGE
ACC=BROWN
HORN=BLACK-NEGATIVE
THESE WILL ALL BE IN THE LEFT KICK PANEL
LOCK=LIGHT BLUE
UNLOCK=WHITE
DOOR LOCKS ARE TYPE 1 POSITIVE
ARM=GREY- POSITIVE
DISARM=TAN-POSITIVE
SENSE=WHITE-POSITIVE
DOOR TRIGGER=DARK BLUE-NEGATIVE
TRUNK IS LOCATED AT THE SWITCH AND IS BLACK AND POSITIVE
BRAKE IS AT SWITCH AND IS WHITE AND POSITIVE
PARKING LIGHTS IS BROWN AND POSITIVE AND LOCATED AT THE 8 PIN CONNECTER NEAR THE PARKING BRAKE
TACH IS WHITE AT THE COIL
Hope this helps ya out
Old 10-08-2003, 07:53 PM   #11
ponchonutty
I see. Well you can always try the Ebay thing. They are usually selling the older style but most are giving a DOA warranty. I could give you an email address that I know this guy who sells them new under $100. Crimestopper or COdealarm you can easily get for that price you stated.
Old 10-08-2003, 08:29 PM   #12
BuzzStPoint
yeah I found the Crimstoppers on the internet just browsing around, Looked nice but they didnt sell them. So I looked on Ebay and found them for amost 60 bucks.
Old 10-08-2003, 09:37 PM   #13
ponchonutty
Re: Re: Re: 1996 remote start help
Yep, make sure you get atleast 2 remotes if not more. They seem not to last more than about 2 years.
Car starts with remote but not with the key?! lilvicklynn Accord/TSX/Accord Hybrid 2 11-14-2010 01:10 PM
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 10:36 AM
remote start help Broken glass General Discussions 1 01-04-2006 09:39 PM
Remote start help? jerseycavyz24 Cavalier 7 01-24-2004 05:17 PM
remote start help legendary 93 Off-Topic 19 12-13-2003 11:52 AM
