Old 12-10-2003, 10:05 PM
legendary 93 legendary 93 is offline
remote start help
i am working on a 96 eclpise and the remote start schematics i got are wrong-- can anyone help me??
Old 12-10-2003, 10:10 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: remote start help
how are they wrong? what is it that you need to know and do you have a auto or a manuel? its not that hard to figure out... let me know
Old 12-10-2003, 10:17 PM
man i have an auto. i got the white wire as the constant 12v, i put both battery wires together to it. i got the starter wire as black and red. but i still need the 2 ignition wires-one thats 12v at the start and on positions and the other 12v at the on position. i think i can splice both of those together but my schematics say that its a black/white wireand a blue wire, respectively. but both of those wires give me 12 v at the accessory positions.
Old 12-10-2003, 10:27 PM
EclipseRST's Avatar
Banned
wire it to the "on" position, do not put a wire to the start position wire! that will just fry the shit out of your starter...cause it will give it a constant 12v so it wont turn off! let me know of anything else you need!
Old 12-10-2003, 10:54 PM
does it matter if the car's ignition wires have 12 v at the accessoory positions, as well as at the on and start positions? and where exactly is the tach wire????
Old 12-10-2003, 11:00 PM
EclipseRST's Avatar
Banned
you can tap into the tach wire behind the stock tach if you really want to add another tach.. and for the remote start, hook it up to the ON position wire, nothing else!!!! do you put the ignition on acessory after you start it? no! it goes to the on position, otherwise your gunna mess up you car and your computer and other electronics wont work right...
Old 12-10-2003, 11:10 PM
the remote start module that i am using requires 5 wires to be interfaced with the ignition wires. 2 to a constant 12v, 2 to ignition 1 to an accessory and one to a start wire, which you are refferring to. my question is in regards to the 2 ignition wires- can i put them on wires that show 12v at the acc position as well as the on and start positions?? it also requires a tachometer wire to be interface with the tach so the remote start module knows how to work. i need to know what color and where the tach wire is, or how to test for it. i have a digital multimeter. i already have the wire from the alarm in the engine compartment, so if there is a wire there that i can use, it would be easier for me.... i appreciate your help man....
Old 12-10-2003, 11:16 PM
EclipseRST's Avatar
Banned
yes you can hook it up to the accessory, but make sure that you hook the right one up to the on position wire! anyways on the tach wire for the starter, tap into your coil pack, i'm not sure on what wire it is right now i will run out to my car and check in 2 seconds... i'll be back and let you know in about 3 minutes.
Old 12-10-2003, 11:18 PM
u r awesome man!!
Old 12-10-2003, 11:27 PM
EclipseRST's Avatar
Banned
ok it was the brown wire that goes into the coil pack... the first wire closest to you on the plug, when it is still attached to the coil pack, hope that helps.
Old 12-10-2003, 11:32 PM
is the coil pack the hub where all the 4 wires plug into right in the center of the engine compartment?? and you are talking about the plug on the right side of the coil pack that has i think 3 wires coming off it???
Old 12-10-2003, 11:42 PM
EclipseRST's Avatar
Banned
yea the plug with 3 wires, its the closest wire to you when its pluged in, it should be brown... let me know
Old 12-11-2003, 06:56 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
DO NOT JUST HOOK UP THE 2ND IGNITION TO WHATEVER YOU FIND. Just because you have an extra wire on the remote start doesn't mean you have to use it. Your car does not have a 2nd ignition wire.
12volts white + ignition harness
Starter black/red + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Power Lock red/blue - Located behind the glove box in a harness. To unlock only thr drivers door on models with keyless entry. Use brown/blue negative(-) trigger at the relays behind the radio.
Power Unlock brown/red - Located behind the glove box in a harness. To unlock only thr drivers door on models with keyless entry. Use brown/blue negative(-) trigger at the relays behind the radio.
Lock Motor blue/black drivers door harness
Unlock Motor blue/red drivers door harness
Parking Lights+ green/white in drivers kick
Parking Lights- green/white 22 awg steering column
Door Trigger red/green - in drivers kick
Dome Supervision -
Trunk/Hatch Pin red/green - driver kick panel
Hood Pin blue/black - fuse box
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock green/white - drivers door harness
Tachometer white AC instument cluster or PCM The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
Brake Wire green/white + brake switch
Horn Trigger green/black - steering column
Old 12-11-2003, 01:16 PM
EclipseRST's Avatar
Banned
he said all he needs is an accessory wire and the ignition wire, it doesnt matter where he goes for the accessory wire as long as it is 12v when the car is on!!!
Old 12-11-2003, 07:39 PM
No, he said on the remote he has 2-12v inputs, 2 IGNITIONS, 1 acc., and 1 starter. His car only has ONE ignition input. Therefore, he shouldn't just hook the extra wire..."you can hook it up to the accessory, but make sure that you hook the right one up to the on position wire." What could happen is it could make the PCM throw a check engine code. Plus, he won't get as much power to the PCM because of the un-needed items being on.
