Old 11-27-2002, 05:38 PM   #1
kaybeejay
Send a message via ICQ to kaybeejay Send a message via AIM to kaybeejay
changed Manual Transmission fluid
I took the Xterra in for the 30K service recently. They changed out the manual transmission fluid as part of the service.
The night of the service, I noticed that there was a fluid leaking from the area of the transmission (or maybe the transfer case) As far as I can tell, that fluid is water. It looks like water, and it feels like water - no I didn't taste it)
When I got in the X the next morning, I had trouble shifting into 2nd gear. In fact, I couldn't get in it at all. Maybe it was cold and something wasn't right.
I just got out and drove around, and it didn't have any problems. The shifting was still pretty "knotchy", but I was able to do everything. The transfer case seems to be working fine.
It feels like the syncho is off. I am also having trouble shifting into 1st gear. It will only allow me into first gear on a dead stop. I can't even shift into first if I am rolling slightly.
I am taking it into the dealer as soon as I get a chance - its pretty obvious that they did something to cause this. It worked fine before they got to it.
Before I bring it in, does anyone have any theories as to what could be my problem?
update:
I took it into the dealer this morning. On the way to the dealer, I was experiencing the same "its hard to shift" problem. Oh course, when I got there and went for a test drive with the mechanic - the problem had cleared up. We talked about it and this is what he told me:
The oil that the dealer puts in (penzoil) is different than what the factory puts in. Its slightly thinner. The dealer doesn't have access to the "good stuff" that the factory uses. This happens on all the cars with manual tranys. He said that my problem eventually just goes away. It helps to let the engine warm up before driving, to give the oil a chance to do its job. (my problem is much worse in the mornings, and improves as it gets warmer)
I didn't have a problem the rest of the morning on my way to work (once the engine warmed up) - so I guess he was correct.
This all still sounds kinda fishy to me. Was the Guy BSing me?
"It may be the soldiers who get all the glory, but its the ENGINEERS who build society"
kaybeejay is offline   Reply With Quote
Old 11-27-2002, 10:37 PM   #2
Schludwiller
XTerra Guy
Schludwiller's Avatar
Kindof sounds like the problems ChuckH had when he put Redline in his tranny. You could do a search, or maybe he'll come across this thread (he visits pretty often).
What's with a dealer not being able to put in the same fluid as Nissan?
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 12-05-2002, 12:22 PM   #3
Schludwiller
XTerra Guy
Gear oils I was able to find, but have not used yet. Our club is trying to locate currently.
Quaker State GL-4 75W-90
and
Noco Gear Oil GLX 75w-90 GL-4
Also from Voy (I'm assuming this is KaybeeJay's post there)
75W85 fluid by Castrol called Syntorq.
This link confirms it's only available in 16 or 55 gallon drums. (Good to be part of a 4x4 club if this is the only quantity you can buy.)
http://www.silcodistributing.com/castrol_products.asp
Old 12-05-2002, 12:49 PM   #4
kaybeejay
I posted this question on another board, and got some pretty good replies from others who had similar experiences. Just an FYI for the people at N4W, in case this happens to you. It looks like Nissan has some weird design spec for their manual trany oils and the dealers are all idiots and don't know. Also the stores don't carry the "Correct" oil, so anyone out there who wants to change their manual tranny oil better watch out.
Read about it Here.
Oh, and nope, I didn't post to the "voy" board. On XOC, there was another person who had a similar problem to me - so maybe it was him. ChuckH has been a great help, as have you Schuldwiller. Thanks. The kind folks at N4W has helped as well.
Old 12-05-2002, 04:08 PM   #5
Schludwiller
XTerra Guy
Called GI Joes and they can order the Quaker State oil. Doesn't help people not in Washington or Oregon though.
Old 12-05-2002, 06:37 PM   #6
OffroadX
Send a message via AIM to OffroadX
How is 80W90 GL4 a "weird design spec" anyway? The GL4 part is not unusual for manual transmissions of any make. The 80W90 part might seem odd since most aftermarket stuff seems to be 75W90.
Brent
OffroadX is offline   Reply With Quote
Old 12-05-2002, 11:17 PM   #7
Schludwiller
XTerra Guy
Brent
Ok, so I'm trying to find "wierd design spec" and 80W90 anywhere in this thread, and can't find it. You mention that most aftermarket stuff is 75w90, but only Quaker State and one obscure company make it (after searching for it). So what was your point?
Old 12-06-2002, 02:38 AM   #8
ChuckH
ChuckH's Avatar
I think Brent got something backwards! Isn't he an automatic guy anyway? :finger:
Yeah, finding GL-4 80W-90 is not a problem at all...everybody makes it and everybody sells it!
GL-4 75W-90, on the other hand, is quite a pain to get hold of. Even rare in Synthetics.
80W-90 is fine to use in a warmer climate but anywhere it drops below 50 degrees it will probably be too thick for good shifting.
ChuckH
ChuckH is offline   Reply With Quote
Old 12-06-2002, 11:18 AM   #9
OffroadX
Guess I was thinking more along the gear oil weights (which are GL5) but with manual transmissions in mind.
Brent
Old 12-10-2002, 09:24 PM   #10
silverxglider
I spent an hour on the phone today trying to find the Quaker State oil on the east coast with no luck. The distribution center in Hicksville, NY will sell a case (12 quarts) of 75W90 but it's synthetic and they won't ship, pick up only. The Syracuse, NY distribution center hooked me up with a shop upstate but when I called, the guy said he won't deal with QS anymore because their prices are crazy. So I gave up and just ordered some Royal Purple from xterraparts.
silverxglider is offline   Reply With Quote
Old 12-10-2002, 11:15 PM   #11
ChuckH
ChuckH's Avatar
I just put the Royal Purple in mine on Sunday and it seems pretty nice so far. My synchros are toast so getting decent shifting is a bit of an acomplishment. So, FWIW, I think the Royal Purple is worth the extra cost.
ChuckH
Old 12-11-2002, 08:18 PM   #12
kaybeejay
Chuck,
I trust your advice on this matter. If your evaluation of Royal Purple is favorable, then I would highly consider swapping mine. The weather is going to get colder and I plan on taking a few trips to the mountains where it gets even colder. I am having enough trouble as it is, with cold starts and its still only 40 or 50 degrees. Imagine the trouble I will be having when its drops to the 30's.
Question for those of you who have changed manual trany fluid.
When I pull the drain plug, how much of it actually drains out? How much of it do I have to refill?
I have never did a drain and fill for the transmission before, so any "step by step" help from the experts would be appreciated.
~Thanks.
Old 12-11-2002, 08:47 PM   #13
ChuckH
ChuckH's Avatar
4x4 manual transmission holds about 5.3 quarts of oil. All the oil will drain out easily in the manual tranny, so you will need to have the full required amount of oil on hand to refill. Best just to have 6 quarts on hand.
Make sure you get a pump of some sort with a fairly long hose. Might want to wait until you get the oil so you can see what size pump threads you need to fit on the bottle. The Royal Purple bottles have a smaller opening than say Amsoil bottles. I had a pump fitted to Amsoil containers so I had to do some container swapping. Not a big deal but you sholdn't ahve a problem finding a pump with the correct fitting and hose pickup length. There's no way to actually get the oil bottle up next to the transmission for filling so a pump is the only way it's going to get in there.
A little advice about the plugs themselves. Make sure you have a very good 1/2" drive breaker bar or a long jack handle that you can slip over the ratchet. Those plugs really stick in there even if you didn't tighten them down that tight at the last fill. Make sure you open the top fill plug first so you're sure you can get it undone. It would suck to get the bottom one off and drain the fluid only to find out that the top one requires the help of the dealer or such. Still, with the proper tools you should be able to get both plugs out. I've used long jackhandles, actual jacks, whatever it takes. Try not to damage the plugs or you may never get them out. I almost blew it last time and had to order a new drain plug. The inside gets out of shape fast if you're really wrenching on it trying to get it loose. Be sure to clean off the plugs too; especially the drain plug since it's magnetic and will almost certainly have some metal shavings attached. Well maybe not yours since it was just done but you need to clean it off anyway. When you put them back in it's a good idea to put teflon tape on the threads to be sure they seal well. You can use the teflon goop too, but I find the tape MUCH easier to use and less messy. Tighten them up snug but remember you have to get them off again later! Just need to be tight enough so they don't leak.
Oh yeah, the top fill hole is your level guage. The tranny is full when the oil reaches the bottom of the fill hole.
Good luck!
ChuckH
Old 12-11-2002, 10:17 PM   #14
kaybeejay
Thanks Chuck,
I don't have a pump, so I think I will go this route:
http://nissan.sadik.net/howto/trany.htm
More how to's can be found here:
http://www.nissan4wheelers.com/howtos/howtos.html
Old 12-23-2002, 01:24 PM   #15
kaybeejay
Chuck or Silverglider,
Any reviews or updates on the Royal Purple? I am getting ready to place my order to xterraparts, and I wanted to check with you guys before I did that - to see if how it was working out for you.
(Chuck - Since you are in the Seattle area - I assume that the climate is cooler/colder than here in CA - so if its working out for your climate then it should work for mines)
Please let me know how its working out for you guys. Much appreciated.
how to check and change the manual Transmission Fluid? cyruslam Del Sol 1 06-27-2006 09:40 PM
manual transmission fluid change How to? icarus649 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 11-28-2004 08:08 PM
Changing manual transmission fluid winner1981 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 10-23-2004 09:23 AM
How do you change/add manual transmission fluid on a gen2 CrazyFukr Integra 7 07-31-2003 02:35 AM
