Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-21-2002, 12:08 PM
CrazyFukr CrazyFukr is offline
Banned
Send a message via ICQ to CrazyFukr
How do you change/add manual transmission fluid on a gen2
My car grinds going 2nd to 3rd gear and I heard that it was because it needs more transmission fluid, do i have to lift up the car and take off the wheel like on the gen3?
Old 12-02-2002, 09:02 AM
Melissa91 Melissa91 is offline
Send a message via AIM to Melissa91
changing trans fluid
Just lift your car up with a regular jack stand (as if you were changing the oil). Your car takes 3.5 bottles of the transmission fluid. There should be a dranage plug at the bottom front right of your car. You may have to lift your plastic mud guards off your car, I know I have to in order to get to it. You'll see it, cause its like your oil plug..kinda big. Then you put in your transmission fluid (WITH A Funnell! or you won't be able to get it in that little hole). There should be a yellow dip stick behind the radiator thats where you need to put the fluid at, you'll see why you need the funnel...lol. If you need to go to a manual of your car at an advance or auto zone to give you more detailed instructions.
Old 12-02-2002, 02:48 PM
Novtec1 Novtec1 is offline
well one...if you have a manual tranny you won't have a dipstick....2 you have a drain plug at the bottom and the fill hole at the top...it is located on the passenger side of the car ..the top bolt is the filler the bottom bolt is the drain. it takes 2.2 qts to fill according to the factory manual use either SAE 10W-30 OR 10W40 oil rated SF or SG grade. the way you check to see if it is full is by sticking you finger in to see where the level is. hth
91 Integra ls
90 Tsi AWD Talon
which one you wanna lose to?
Old 12-06-2002, 09:13 AM
Smile thanks
thanks for that correction
Old 12-06-2002, 09:29 AM
check fluid
I always thought that in order to check the trans fluid is to have the car idling for a minute and then check the dip stick? I have an automatic, so thats probably why things are different.
Old 12-06-2002, 10:49 AM
no problem...5 speeds and autos are different... 5 speeds don't have a stick to check it you gott check it the hard way:o
91 Integra ls
90 Tsi AWD Talon
Old 07-30-2003, 05:37 PM
vmp00 vmp00 is offline
Send a message via AIM to vmp00
My Accord Grinds goin from 1st to 2nd. and i plan to check and replace the fluid.
i cant seem to find the filler bolt, the only thing i found was alittle nozzle with a rubber cap over it, but the nozzle is too small to stick ur finger
can someone please help
thanks
V. P.
Old 07-31-2003, 01:35 AM
BullShifter's Avatar
Re: check fluid
Hondas check the auto trans fluid with the engine OFF, after warmed up.
Changing the fluid will not stop a grind.
Both fill & drain plugs are on the right side. Always remove the fill before drain, just in case you cant the fill out. Drain plug - 3/8" ratchet // fill plug is 17mm (i think - to much smokey tonight)
Changing the manaul fluid with out a lift & fluid pumps is a pain, your better off saving yourself the aggrevation & letting Jiffy Lube do it for $20.00. Filling is the tricky part if you dont have the correct "tools"
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
