Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 06-27-2006, 06:55 PM
cyruslam cyruslam is offline
how to check and change the manual Transmission Fluid?
how can i check the level of manual transmission fluid ??
i can only see a black rubber plug on the top. when i unplug it, i didnt see a stick or anything that i can check.
Also, i have read another forum people said add about 2.5 quarts to b-series will be enough.
so how much is "2.5 quarts" in litre or ml??
Old 06-27-2006, 09:40 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: how to check and change the manual Transmission Fluid?
To check the level, open the fill plug on the side. Stick your index finger in the hole and bend the first part of your finger downward. The rule of thumb is if you touch oil, it's ok; if not, you need more. As for the conversion, try google.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
