| Register | FAQ | Social Groups | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
07 2500HD 6.6L Brake Light Out
I just bought an 07 2500HD Duramax and the right brake light and blinker dont work. I swapped bulbs and checked the fuses on drivers side dash and under hood drivers side, all looks ok but it still doesnt work. No voltage at the bulb. Is there another fuse somewhere I am missing?
Re: 07 2500HD 6.6L Brake Light Out
Not sure with your '07, but my '98 Sub rear lights are in a circuit board that fails occasionally.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
ok found it, under the fuse block in the engine compartment there are 5 plugs. One of the plugs has 2 of the 4 clips that hold it up to the underside of the fuse block broken so it was settling down. Found a replacement plug for $20. Now I just need to find 1 of the 2 clips that holds down the fuse block without buying a whole new fuse block.
I am surprised you had to go that far back. |
So my diagnosis of the original cause is that 1 of the 2 large grey clips that hold down the fuse block was missing allowing the back of the fuse block to raise and lower a little. The 4 tabs on the plugs dont actually clip onto the fuse block but sit in grooves on the under bracket below the fuse block holding it up agains the bottom of the fuse block. My thought is that the fuse block moving up and down allowed 2 of the tabs to fall out of the groove and get pinched and eventually broke. now with 2 tabs missing the side of the plug it pulls away from the fuse block enough to break contact.
Again I just bought this truck so I don't know how long the clamps have been missing but I am fairly confident once I replace the plug and find a clamp to hold the fuse block down this will not happen again, until the rodents move in... Thanks for the help |
one forum member removed the uper intake manifold. when this was worked he put stress on the wire harness and broke some wires under the fuse block.
