Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse 2000+
Old 03-12-2012, 11:31 PM   #1
ARK51294
2002 stalls
2002 GS starts runs then stalls turn key nothing...Wait, then it starts.. Sometimes when it does it then you drive it has a hesitation but then it goes away.. Dosent happen all the time.. Couple times a month since it started..
ARK51294 is offline   Reply With Quote
Old 03-14-2012, 07:28 AM   #2
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Re: 2002 stalls
Has it thrown a check engine light when it stalls or runs rough?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 03-14-2012, 09:30 PM   #3
ARK51294
Re: 2002 stalls
Its not actually stalling just like kinda of hard to explain like drops power for a sec or hesitates then it gos back to normal the srs light flashed when it happened... the codes that are showing up are p0421,p0128,po455.. 455 is a leak in the fuel system put a new cap on and it went away but now is back.. 421 is an exhaust leak or o2 sensor... replaced both sensors and stil shows up.. those 2 have been there since i got the car in june the new one is the 128low coolant, thermosat or ect fault...
Old 03-15-2012, 07:21 AM   #4
SilvrEclipse
Holset powered 420a
Re: 2002 stalls
Have you done regular maintenance lately? Might want to try plugs and wires just to eliminate that if they havent been changed recently. Sounds like you did the o2 sensors recently so those should be ok. Also you should try and fix the fault codes. Its hard to say if there is a direct correlation between a specific code and your issues. What doesnt make sense is why the SRS light flashes.
98 Eclipse GS Turbo
2001 BMW 325i - DD
2002 1500 sierra starting problems jesushchrist Sierra 6 06-27-2010 09:39 PM
2002 stalling venture venturecrazy Venture 7 12-06-2007 07:58 PM
2002 stalling mad1985 Taurus | Taurus Wagon 11 10-17-2007 01:26 PM
