Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-16-2005, 08:28 PM
venturecrazy venturecrazy is offline
Unhappy 2002 stalling venture
ok purchased a 2002 venture 7 months ago. 41,000 at present at least 6 times venture has stalled. No sputtering or anything. Once when I put foot on brake to go to reverse, once when crossing a major intersection. I have NO warning. Fuel filter was changed 2 months ago. Fuel injector cleaner added. Does it very unpredictably. Any advice? I know the mechanic thinks I am nuts, but i need safety for my family.HELP
Old 09-19-2005, 02:41 PM
GMCritic GMCritic is offline
Mine does this when I use bargain gas.... Both times in the last year when it's done this, it was when I used cheap gas. I only use Chevron now and haven't had any more stalling... (and no, I don't work for the gas industry or Chevron)...
Keep us posted if you find it's something else...
Old 10-11-2005, 03:39 PM
mmorales mmorales is offline
Re: 2002 stalling venture
I know this post is somewhat old and you might not need this information anymore, but I had a similar problem and someone here on the forums told me to put diametric creme on the connection below the driver's side rear door that powers the fuel pump. I have not had the problem since. It seems that the connection is vulnerable to getting wet and can cause the fuel pump to randomly lose power. I hope this helps. If you need more specifics about where the connection is let me know.
Moses
Old 10-12-2005, 07:54 AM
cdru's Avatar
cdru cdru is offline
Re: Re: 2002 stalling venture
I beleive you mean dielectric grease, not diametric. Dielectric grease will act to prevent moisture from corroding the connection.
Vinyl adds horsepower, right?
Old 10-13-2005, 08:22 AM
You are right, I should have said "dielectric grease". Don't know where I got diametric creme from...sounds like something medical.
Old 12-02-2007, 03:03 PM
Tyler5570 Tyler5570 is offline
I have had the Same issues , I had just got gas and as soon as i pulled out into the intersection my venture stalled, its been two weeks now i have replaced the fuel filter and check fuse also both are new now , but i get the feeling that the fuel pump is not working , it has been raining and snowing alot , how hard is it to change the fuel pump?? can anyone suggest anything else??? what is and where is the fuel pybass plug ?? i seen on another forum to check that ?? I need help christmas is going to suck if i have to go by a new van
Old 12-04-2007, 08:42 PM
Efix Efix is offline
The plug is underneath the car (chassis) just behind the driver seat as described in an other post above. I just had the problem the day before yesterday: the van would not start, I thought it was the fuel pump. I got the car towed home. I cleaned that connector and it is running fine now. I just returned the fuel pump I had purchased - saved $270 !
Old 12-06-2007, 06:58 PM
I probably should update my earlier post. I found that it wasn't the brand of gas I purchased, but whether or not I filled the tank too full. If I try to put too much gas in the tank (when putting in more than when it first clicks off), then it's almost guaranteed that it'll stall within the first seven miles after filling up... when I don't overfill, it doesn't stall. Not sure why.
However, I am dealing with a fuel gauge needle that is no longer accurate after it goes below half tank... after that point it'll bounce around all over the place, but I think there's another thread around here that talks about this.
