Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Register FAQ Social Groups
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-21-2010, 12:23 PM
fastmoney fastmoney is offline
brake piston?
I have a 1996 cutlass iv been having brake problems squeaking etc maybe the rotors are warped i'm not sure.
and i just wanted to know if the dual piston on the front are they suppose to come out and disengage simultaneously...I took off the wheel and put a piece of wood in the caliper where the pads usually are and had some one press on the brakes.......on driver and passenger side one piston comes out before the other the one closer to the brake line on the caliper comes out first and the other is about half way out...when the brake is applied constantly it eventually catches up with the other piston..........Is this normal function? is it the master cylinder since both sides do this? Thanks
Old 09-22-2010, 04:37 PM
maxwedge maxwedge is offline
A990 racer
Re: brake piston?
Normal, when the pistons see equal resistance from the brake pads things even out.
Old 09-22-2010, 11:42 PM
Re: brake piston?
i know it was sorta a silly question but hey i didn't know thanks
Rear disc brake piston won't budge LesMoore Taurus | Taurus Wagon 7 05-13-2006 02:30 AM
disc brake piston dokker Monte Carlo 3 01-05-2006 02:42 PM
99 Maxima Rear Brake Piston depfrz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 01-03-2004 12:12 PM
