Old 05-09-2006, 08:48 AM
LesMoore LesMoore is offline
Rear disc brake piston won't budge
'97 Taurus: any ideas why a rear disc brake piston will not push back into a caliper? I've tried with might, and it won't budge.
Thanks!
Old 05-09-2006, 09:46 AM
Re: Rear disc brake piston won't budge
OK, I think I figured it out. It seems those pistons need to be "screwed" back into place. Let's hope a set of channel locks will do the trick
Old 05-09-2006, 12:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You're likely to really score the piston and possibly shatter it if you try to screw it back into the caliper with a slip joint pliers. Most chain auto parts stores will have a loaner tool that you can borrow for no cost (as long as you return it in 90 days or so) to make easy work of compressing the rear caliper. Make sure to get the slots aligned properly when you stop compressing the caliper. They need to align with the tabs on the brake pads.
-Rod
Old 05-11-2006, 11:03 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
theres a 'rubix cube' thats needed the thread the piston back in, and as mentioned by shorod the piston will need to be aligned just right for the pad and e break to fall into place
Old 05-12-2006, 07:21 AM
Yep, bought the piston tool, all went well. Thanks for the replies.
Old 05-12-2006, 05:52 PM
last guy i heard say that cost him 700 bucks, so however much it cost you, feel lucky you didn't rake the threads
Old 05-12-2006, 08:47 PM
$12.99 - Pep Boys. It's really a rudimentary tool, unless it's not the same tool, but it did the job.
Old 05-13-2006, 01:30 AM
im sure pep boys got ya what you needed, and that is not a bad price for doing the job once in a great while
