Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 12-21-2009, 10:08 AM   #1
joseriverasg
95 silverado abs light is on and smells like brakes
i have a 1995 silverado v6 my abs light is on and after you drive it for awhile the brakes on the front passanger tire smell. replaced caliper brakes and brake hose but there is no change...can you tell me whats wrong?
joseriverasg is offline   Reply With Quote
Old 12-21-2009, 10:13 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 95 silverado abs light is on and smells like brakes
No.
But we can tell you what to look and check for.
Did you do both sides?
Is any of the wheels draging after hot or using brakes?
Is brake caliper sides free or sticking?
Is it the red or yellow ABS light?
Have you checked for ABS codes?
MT
MT-2500 is offline   Reply With Quote
Old 12-21-2009, 10:15 AM   #3
j cAT
how about driving it when cold ONE mile , then carefully touch all brake rotors/drums and compare for heat/temp should be same...it not the hot one is bad...
even though you replace calipers this does not mean this is gonna fix the problem...as other things can effect this..
j cAT is offline   Reply With Quote
Tags
1500 , abs , silverado
