Go Back   Automotive Forums .com Car Chat > Honda > Del Sol
Old 10-15-2009, 04:46 PM   #1
DSM_tuner
Send a message via MSN to DSM_tuner
Knowledgeable Honda owner needs ignition help
Hi guys,
I have a 1993 civic.
I believe i have this problem narrowed down to the coil but i would like some other opinions before i order this part.
Problem: Driving down the and car died. Power was still on but just died. Car would not start because i now have no spark from the distributer.
What i have Tested/Replaced: I replaced dist.cap and rotor. I tested the coil. Primary resistance is at 1.1 Ohms and secondary is at 13kOhm. For the icm i have 12 volts (when connected to coil) across the two wires that connect to the coil. With coil disconnected and light bulb in place of it, it turns off and on when i turn it over. This tells me that everything b4 the icm and output of icm is ok.
1). The recommended primary resistance is between .6 and .8 ohms were mine is 1.1 ohms. Could this be the coil or icm problem?
2). Also could an icm ever "kind of " work? what i mean is could the icm be switching but not be outputting enough voltage to the coil?
Let me know if i was not descriptive enough.
Thanks for any help
Its taking six opposing turns without traction at anytime.
DSM_tuner is offline   Reply With Quote
Old 10-19-2009, 09:48 PM   #2
DSM_tuner
Re: Knowledgeable Honda owner needs ignition help
Replaced the coil and she runs!! You cannot always go by the resistance test I guess.
Old 12-28-2009, 12:46 PM   #3
DownToGround
most of the time i replace them together.. if 1 just went out the other is soon to follow.. and yes the icm does act intermitent, but so does the coil when it goes bad.. i have known good ones laying around so when it happens i can test which one is bad..if you get an msd coil youll elliminate the coil problem
DownToGround is offline   Reply With Quote
Old 02-06-2011, 11:12 AM   #4
FrodoGT
FrodoGT's Avatar
And yes, the icm almost always dies slowly. Youll notice the tach jumping first, and if you are lucky will throw and icm error code before she goes. But the coil and icm are best to be replaced together unless your doing it for diagnostic elimination purposes.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
FrodoGT is offline   Reply With Quote
