| Latest | 0 Rplys |
07-17-2009, 12:32 PM | #1 | |
1996 Outback Subura Vibrations
I am having a major vibration problem. Was told that it was the transmission motor mounts, replaced that. Then it was the tires, had them replaced. In addition to a front end aligment. During that the stated that I had a broken front right axle, replaced that.
The vibration is still continuing. Now am told that it is the hub assemby. Any help or comments would be greatly appreciated. |
07-17-2009, 05:19 PM | #2 | |
Re: 1996 Outback Subura Vibrations
When does the vibration occur? Speed? Need some more info here.
07-17-2009, 07:04 PM | #3 |
07-17-2009, 09:32 PM | #4 | |
Where are you feeling the vibration? Everywhere, in the brake pedal, steering wheel, seat etc? Have you checked the engine mounts? They can be loosened and the engine is able to be moved side to side. I've had a few that the nut that holds it to the crossmember was not tight and caused some movement. Is there any contact with a solid surface by the engine/exhaust/trans?
10-16-2009, 01:22 AM | #5 | |
AF - Advisor
Manual transmission? or Auto?
"I cut the header twice, and it's STILL too short!" |
