| Latest | 0 Rplys |
#1 | |
Security light car won't start
My GRAND AM WOULDN'T START AFTER I PARKED IT AT THE MALL.. WELL I LET SET 15 MIN.. AND IT STARTED. SO IF YOUR SECURITY LIGHT FLASHES CAR WON'T START TRY THIS.. LEAVE KEY IN ON POSTION FOR 10 -15 MIN. AND TRY STARTING. IT WORKED FOR ME TODAY.GOOD LUCK.
#2 | ||
out saving the world
![]() Join Date: Jul 2005
Re: Security light car won't start
Welcome to AF !! And thanks for the tip.
This is the actual procedure; Quote:
1999 Grand Am SS 3.4 OHV ![]() |
#3 | |
My 2001 does this and i leave key on in the run position as long as the security light flashes approx. 10 minutes and light will quit flashing and stay on. Turn key to off position and start the car. I have changed to my spare key wich i was told there is a chip in the key and now my problem has quit. Probably just jinxed myself. Hope this helps.
#4 | |
You would not believe all the things we tried to fix the 2002 Grand Am that would not start. Replaced ignition switch, replaced neutral switch.......then found the forum and doing the security relearn procedure worked like a charm!!!
Thank you! Steve |
#5 | |
Just read above tip. When security light went off (About 11 minutes), turned off, and then....IT STARTED!!!!!!
Thanks forum! |
#6 | |
The problem I have is that this "security light on - car won't start" problem happens too often and at random times. It'll happen about 3 times in a week then won't happen again for a couple months.
Does anybody else experience this? Is there something wrong with the computer? Fixable? |
#7 | |
If you're not completing the whole sequence above 3 times, then you will have to do it again and again.
Though if you've done this 3 times and you continue to experiance it then you could have some other component in the system not working. Usualy the problem is the ignittion switch or lock cylinder. Worse case its the BCM or PCM problems/errors.
